Romeo vs. Windsor
delling3
Sterling Heights, MI
So, what is the best (easiest) way of knowing if you have a Romeo or Windsor 4.8 2V? I am finding conflicting information.
My car is a 1996. The VIN has an "X" as the eighth digit. From what I found on the LMR website, I take this to mean it has a Windsor motor. Is this correct?
delling3
delling3
Good to know. I am getting ready to start tearing down the top end for a cam swap, and I was worried that the cam gears might be the pressed on type (Windsor). Knowing it's a Romeo eliminates that worry.
apsmith49921
Are you doing a teardown of the front too or just gonna slip them in?
Silver95bird
Look for REP or WEP on the valve cover stickers
Sent from my moto z3 using Tapatalk
joe65
Agree with adding the heads. Pretty easy to find a set on fb or ebay.
delling3
delling3
Budget just doesn't allow the head swap. If I was going to go that route, I figure a couple hundred bucks for the heads, then the costs for a machine shop to do a clean up on the heads, head gaskets, bolts, and I am easily in for $600-$1000 just for the heads. I picked up a FRPP intake from PinkieT and a set of Bullet Cams for the NPI engine from OLD H2S. I am not sure what this will all add up to HP-wise, but I will have to be satisfied with this, cuz I got other things I want to spend money on.
joe65
yes, you're right, it snowballs easily.
Srchop16
