bigjohnson4.6gt
- Joined
- Dec 23, 2006
- Messages
- 3,322
- Reaction score
- 0
i got the car up on jackstands right now, and im letting the pb blaster soak into the sway bar end links, hopefully i can do this today without any problems
o yeahPassenger said:Soak every damn nut you see under there that is even close to where you will be working, just incase you forget other bolts.
Red96GT said:Get pics up when done. :boink:
m0n0x1d3 said:Try puttin another wrench on the wrench you are using, it makes a great quick breaker bar.
I know it sounds like common sense, but it has worked for me coutless times even when my breaker bar wouldn't make a stuck bolt budge. A buddy of mine showed me and i felt pretty dumb never thinking about it before. Just a thought.
GL man, and remember if it still wont budge, MAP gas torches are your friend.
hahahaha yeah i figured that out yesterday when i tried itscarface said:if you dont take off the nut from the tie rod he wont be able to get the control arm to drop down enough to get the springs out.
that sucks for him then, because i left mine on when i put on my springs.scarface said:if you dont take off the nut from the tie rod he wont be able to get the control arm to drop down enough to get the springs out.
so yours just dropped all the way with the tie rod connected?DFG_Pimpin said:that sucks for him then, because i left mine on when i put on my springs.scarface said:if you dont take off the nut from the tie rod he wont be able to get the control arm to drop down enough to get the springs out.
