RTV'd Intake manifolds
shock357
So the PO of my car decided it would be a grand idea to RTV the trickflow upper/lower manifolds together. Despite all my best efforts i cant get it to budge.
any idea's on how to fix this retarded idea someone had?
96cobra_12
It shouldn't be that hard to separate. Are you sure you don't have anything else holding it on?
duff daddy
Put it in a heated parts washer get it up to temp with the heated water/air and go from there.
shock357
sorry, i guess i should clarify. Its on the car. i tried putting a crowbar in the TB inlet and tried with all my might, all i did was rock the motor on the mounts. I have no clue what type of RTV it is, all i know its black.
g36 monkey
Orlando, Fl
black usually doesn't hold like that. this might be bad advice but I know my redneck father would tell you to get a blow torch and heat it up.
that is if you dont have a heat gun of course ;p
or drive for a bit let it warm up on its own, throw on some gloves and try to pull the bolts and peel it fast
