runnig with no iac
98saleen88
i had a problem with my hangin idle, so i read some where that if i just disconnect to iac and rise the idle, i should be fine.....i did that and i the throttle is now very responsive..its it ok for the car to run like this???
ThePope
How responsive is that beast now? LOL
vermilion
maryland
if emissions isnt in your area go for it. other than that i wouldnt. thats just my if its not broken dont fix it. if it hangs at idle. just could be something else? any CEL codes?
98saleen88
yea i tried most other options that ppl could think of. for a while i thought it was my tps..but its set at what its supposed to. oo this was bascially the only thing left
ThePope
Could of just cleaned it or just by a new one. But im sure you tred that already.
black_96gt
This sounds new to me? :*( I have used an extra gasket with various diameter holes to try and fine tune my idle. The car was tuned but my tuner never set up anything to fix the hanging problem. Do you just unplug the IAC, rasie the idle manually and reconnect? I have an SCT SF tuner so the idle speed is perfect in gear and nuetral. I'm curious about how this works??
voidfinger
... i don't know, i think he was refearing to the iac restrictor plate... works well from what i'm told. I have no clue what your talkign aobut though...
Jrgunn5150
No, he's talking about unhooking it altogether, and then bumping the idle screw to compensate for it. Which would have it idling at around 1200 rpm.
voidfinger
::D
holy snikkeys
just clean the hell out of it or get a new one and do the restrictor plate dude.
Jrgunn5150
Lol, that's why it's so responsive.
I did this with my truck back in the day before I fifgured out how to work a chocke, same result.
