running hot
MustangJunkie
a buddy of mine is lookn at a 96 4.6 and tha person say its running hot after bout15 min of driving said no water n oil or coming out of exhaust but the car is about 2hr away from us and kinda whated a idea of what it could be b4 we drove that far to look at it any advice would b great i dont know much bout tha 4.6s thanks
pp_puncher
Possibly stuck t-stat,or maybe air pocket in the coolant which very simple to fix, dead fan, or ccrm for fan, which you can buy a new ccrm $$$, or cut the pig tail and run a toggle switch(there are write-ups). An easy way to test the ccrm and the fan is to turn the a/c to max and the fan should come on, if it doesn't then one of those is your problem. That is all I can think of at the moment.
Lee12609
is it loosing coolant? low coolant light "should" be coming on to alert the owner. passenger side seam on the radiator is a pretty common area for these cars to leak. is the fan working, possibly the CCRM not working therefore no fan, or bad fan motor.
oh and i see your avatar is from Zmax, i was there were you?
MustangJunkie
yes thats me beside the 1 and only jack roush that was cool as hellOOOOand got my coat signed
DropTopPony
South Jersey
The 96's had a silent recall for the radiator/fan assembly being below par and overheating. If you complained they upgraded you to the newer 97 up rad/fan assembly for free.
Mine overheated right in front of the Ford dealer and puked coolant all over the road and they said nothing was wrong after having it for a day. I never actually checked to see if they swapped parts after reading of the recall several years later.
