doc_phibz
95 gt running hot. does not over heat though because fan kicks on and keeps temp in check. car sat up for a while b/c of other issues, now running but is running hot. just put in new radiator and hoses. timing is perfect. motor is solid, compression test done, block test done, oil looks good. before car sat up it ran relatively cool and temp gauge never ran over the "o" on "normal".
not sure why running hot. one thing though is that after I sent the car to the mechanic, they messed with the PCM and the Autologic chip. not sure if the chip had something to do with the air/fuel ratio. now when I try to hook up the chip, no matter what setting, it kills the engine. I just mentioned this because I'm pulling at strings.
