S281 wing studs.
BruhBrahBrad
Anybody know what size and where to get em? I bought a wing with no studs, shitty thing is I think one of the holes is too big.
19mustang95
1. take wing to home depot, lowes, ace hardware(i love this place)
2. try out different studs
3. buy four of the right size
4. ??????
5. f*ck bitches and get money
Win
Kennesaw, Ga
The bolts weren't fiberglassed into the wing??? They should have been.
Since they weren't just do as said go and get bolts and washers and nuts. Done
5litrarag
go to the hardware store and find some of the correct size and pitch.... mine had all 4 screwed into it when I got it.
Slapped a little double stick tape in areas to keep it from rubbing on the paint, put it thru the holes on the decklid, popped 4 nuts on and took a pic. hahaha
badass96gt
Just send me the wing and Ill mount it on my car and post detailed pics so you know how to do it! lol
JoshHooten
Hiram, GA
Its to hard to line the bolts up so do what i did get the bolts get som epoxy glue and place a drop at the tip of each bolt screw them in get a couple of turns out of them let it sit then take a dremel and cut off the bolt heads sith the wing in place and put the nuts and washers on then makes putting it on and taking it off much quicker and easyer
19mustang95
you buy studs.
JoshHooten
Hiram, GA
DFG_Pimpin said:
no mine came with some bolts but it was just to hard to line up after i epoxyed the bolts in it just takes a sec to put it on and take it off but make shure the bolts are going to be long enough
you buy studs.
