Seal lube?
eliyarbrough
Nocona, TX
I had a pretty big leak in my pass side seal on my rack & pinion, my mechanic says. He thought that you cannot replace just the seal. This product was referred to him by a guy who fixed up all kind of motors! It was $15, so I tried it. My power steering fluid level has not lowered any. I hag my mechanic look because I cannot remember where it was.
The stuff works for all kind of stuff, too. Oil leaks, Engine wear, Transmission slip, Fuel efficiency, increase power, Clogged fuel injectors, carb jets, Clean sticky valves & lifters, Ease Rack & Pinion stiffness, Boost Octane - stop knock & run-on, Limited Slip chatter, Radiator Leaks & Cracked Blocks; I copied from the website.
Think about using it if you have any leaks!! See ya!!
http://www.seallube.com/
mich_666
sounds like some miracle product... seems to claim to fix anything.... :banana:
eliyarbrough
eliyarbrough
Nocona, TX
Fixed my leak all up! It had been leaking out for maybe 9 months. I just kept filling the fluid up! I would forget all about it until it would whine. I could also feel it in my steering wheel. It always ran out when I parked my car in my spot, too! I got lucky it did while I was out running my errands! I was going to my mechanics anyways! I just moved it from like stop 3, to stop 1. I asked him about it then. As soon as I would refill it, it was perfect again. I forget damn near everything now! It just worked out, so it's now fixed!
uncltrvlnmatt
Pa.
When your rack starts leaking again, send me a P.M. I have the rack off my Mach junker I will be able to sell you. Just make sure they are the same.
eliyarbrough
eliyarbrough
Nocona, TX
How do you think I would find out? I ask y'all that kind of stuff. Don't mean to be a smartass!! I'm really a dumbass, ironic. I don't know jack about much of anything!! I joined this site to help me figure out my car stuff. I would say learn. If I don't print it out, it's like I never evensaw it!
eliyarbrough
eliyarbrough
Nocona, TX
I e-mailed and asked them. They say it will work for years! Sorry, I cannot remember any more of it! I was glad to get that out!!!
