should I lower it?
427danderson
lower it :)
I am in the process... I have the Eibach Pros... ~1.5" all the way around... the sportlines are a full 2" I kinda wish I went with them... but I got a deal on the Pros...
Rice_slayer
I think you need more rubber first. 245/35 on an 18 looks WAY too small to me. I have 275/35 on my 18s and I wish i had 275/40s instead. Also, What are your roads like? Im putting ford c springs in soon and would go lower, but due to speed bumps in my schools parking lot and the general rough condition of our roads, the C drop is good enough :).
X
x182dan
ok what about iso's front and rear? Poly or not, if anything?
Unless you want it really low i'd suggest isos, poly ones are nice cause the stock rubber ones turn into junk as they age.
X
x182dan
will the poly ones make noise? Right now I have teh stock rubbers in there and they are pretty shot on the rear control arm.
justinschmidt1
javi said:
35's and sportlines no isos:
Shits lifted, you need to be tucking
mikey94gt
The poly ones wont make noise, and if they do, hose em down with dry teflon or silicone lube. There is some lube you are supposed to use with them, but I dunno where to get, and its messy.
mikey94gt
well, there ya go, they wont make noise!!! some do, some dont. its really 1 in 10 that does anyways. I know the bushings on the control arms will make noise if they are installed dry.
