Side rocker panel holes
grimreaper_72
BENEDICT, NEBRASKA
So i went skirtless, those of you have done it what did you use to cover the holes with?
Checked my local parts store and hardware store couln't find anything that i thought would work
Any ideas or links to something, i need like 34 total tia
ReplicaR
I left mine exposed, but it's not my daily, nor does it see rain, so rust is not something I'm concerned with
mcglsr2
Orlando
I think your best bet would be to try to find those plastic plug things, but in a thicker diameter to fit the holes. Similar to the smaller ones that were used to hold on the trim pieces under the car. If you wanted them to blend in, you could probably paint all the heads the same color as your car, and them pop them in.
