slow start up on cold engine?
sinister5oh
Greensboro, NC
recently just fixed a misfire issue by replacing my distributor. before I fixed the misfire, I still had this problem, too.
when the engine is cold, it will take 5+ seconds for it to start. it's not turning over slow, it sounds good and sounds like it wants to start, but it just won't as quickly as I want it to. I can shut the engine off 20 seconds after it's been started, turn it back on and it will crank up quickly just like it should.
i have this idea that it could be the cap/rotor. I replaced them shortly after I got the car, I has no misfire issues, then a week later the misfire creeped back on. the cap seemed to be getting burned up quicker than it should, and I think that was due to the bad distributor. a fellow forum member stated that when his dizzy was going south, his cap and rotor were getting burned up as well. when I replaced the distributor, I did NOT replace the cap and rotor as well. I will sand down the contacts a bit and see if that helps any. with the new distributor the cap and rotor should wear normally again.
i also thought fuel pump but, you know, when I turn the key to KOEO before starting, you know, the fuel pump makes that nice "bzzzzzzz" :) it doesn't sound weak, sounds normal to me, but I don't know if how it sounds gives any indication to a failing fuel pump.
anyone have any ideas other than the cap and rotor? as always, any input is appreciated!! :)
new distributor, o2 sensors, plugs, plug wires, fuel filter, IAC valve, ignition coil. once again, I did NOT replace cap and rotor when replacing distributor. didnt clean the contacts either, which I'll do next.
MODS: f303 cam, long tubes, no cats/h-pipe, JLT CAI
95GT86SS
Didn't the new dizzy come with a new cap and rotor?
95 GT BBK CAI TB MSD 6AL O/R H SLP LM1
Coming soon GT40 Heads Intake and e303 cam with Long tubes
sinister5oh
Greensboro, NC
nope, just distributor only. I've been at work all day, and rode my motorcycle today. when I get home I'll sand down the cap contacts and let you know if it helps any.
any other thoughts on the slow start up?
sinister5oh
Greensboro, NC
when I prime the fuel pump by turning the key on and off 3 times, the car starts up noticeably quicker. must be the pump, but at least it's not totally shot. not too worried about it now...maybe a future project later on.
95GT86SS
If it's the pump, it's a warning that it will go out shortly. But I'd change the fuel filter and see what that does. Maybe it's having to push past a dirty filter
BlkoutGT
MO
Sounds like its time for a new pump... Could last a while if you prime it first. But the clock is ticking.
jeanfltns01
