SN95 ET Thread - Post Your Timeslips
stang94X
Re: SN95 ET List
94 GT automatic convertable
car weighed 3540 lbs. with me in it ( i weigh 150 )
launched at 1,500 rpm
Hoosier drag radials w/26 psi
rt- .1061
60ft- 2.15
330ft- 5.9
et @594ft- 8.46
1/8 et- 8.93
1/8 mph- 80.65
1000ft et- 11.61
1/4 et- 13.682
1/4 mph- 103.85
i am kinda dissapointed with my time cause before on shitty ass no-name brand street tires and with stock 2.73 gears i was running a 14.1 and now with drag radials and 4.10's i'm only hitting mid 13's, i am trying to lower the weight and any other suggestions on how to help my ET would be great
95PGTTech
Re: SN95 ET List
R/T: .806
60': 2.181
330': 5.924
1/8: 9.014
MPH: 80.17
1000: 11.621
1/4: 13.812
MPH: 103.36
finally. atco sucks. sumuto 315's suck worse.
A
ALITL8
Re: SN95 ET List
95PGTTech said:
R/T: .806
60': 2.181
330': 5.924
1/8: 9.014
MPH: 80.17
1000: 11.621
1/4: 13.812
MPH: 103.36
street tires suck on the track. get some 315 Nitto 555R Extreme Drags, theyre fairly affordable ($175ish each). when i put them on my car they knocked 2/10's of my sixty on stock suspension parts and lowering springs (2.2's to 2.0's consistantly).
nice time slip btw O0
95PGTTech
Re: SN95 ET List
thanks man, I keep thinking that is slow for this car. After more runs, we're consistently going 14.1 flat at 102 even with just about exactly 2.3 sixty foots no matter what I do. Too much throttle it spins, too much clutch it just gets out and feels slow. I think I need the same slow clutch slip with a lot more rpm (been doing 2000).
We really want some sticky tires but need a rear first...
A
ALITL8
Re: SN95 ET List
on DR's you should be okay on the stock rear... im running my stock rear end with 170K miles on it. once i get my lca's and subframes installed we'll see how she hooks up. im also having a PI motor w/VT stage 1 cams, BBK (the black w/SOHC) or C&L plenum, 75mm BBK TB and a better flowing exhaust installed at the same time so...
i'll probably break something :-\
stang94X
Re: SN95 ET List
i have a stock trac-lock and stock axles with 4.10 gears and hoosier drag radials and my rear end is just fine
QwanSanchez
Re: SN95 ET List
15.105
96gt with lowering springs, mgw short shift, o/r x with bad exhaust leak, and supa bald tires :(
hopefully get another run in and get into the 14's before the tracks close this year
Re: SN95 ET List
QwanSanchez said:
15.105
dont feel bad about it, just think of it as A LOT Of room for improvement.......there will always be another tenth you can take off that time :)
A
ALITL8
Re: SN95 ET List
Snakebit said:
QwanSanchez said:
15.105
yep, thats what some of my first slips looked like... my personal worst was a 15.3xx. that was with flowmaster super 40 weld ins, gears and worn out potenza re910's. im looking to be somewhere in the 13's next time out :naughty:
QwanSanchez
Re: SN95 ET List
ALITL8 said:
Snakebit said:
QwanSanchez said:
15.105
well i'm heading back to the track soon with new tires, changed the o/r x for an o/r prochamber, and a set of 3.73's so that will help i hope. Also i think that with the MPH i was pulling ( 6 runs constently around high 92 low 93 mph) if i had some traction i would have made 14's anyways, but who knows we'll see what happens.
A
ALITL8
Re: SN95 ET List
what tires are you going with? drag radials knocked 2-3/10's off my 60'... damn im missing my car right now!!!
TheBab
Re: SN95 ET List
11.7 @ 116
That tosses me on the site under the top 10 eh? :D
1sick95
Re: SN95 ET List
Results for the White 94 at our local group's track day earlier this year ... We hope to break into the 12's after we beef up the suspension and replace the tired differential.
60' - 2.07
1/8 - 8.72 @ 83.32
1/4 - 13.42 @ 105.49
TW Heads, B303 Cam, TFS Street Intake, 1.6 TFS RR's, AFM PP, 90mm MAF, 75mm TB, Exhaust, MSD Ignition, SCT Chip, 3.73's, B springs ... ran on Nitto DR's
S281 #39B
Re: SN95 ET List
1sick95 said:
Results for the White 94 at our local group's track day earlier this year ... GF did the driving as the white car is her's ;)
60' - 2.07
1/8 - 8.72 @ 83.32
nice run
Passenger
Re: SN95 ET List
[email protected] on a 1.96 sixty in the heat.
95 GT with dynomax ultraflows, o/r h pipe, no cats, LCA's, underdrive pulleys and some juice.
12's or bust. Coming soon :)
S281 #39B
Re: SN95 ET List
my husband said the same thing(except 11's) and we ended up getting a new trans.
Passenger
Re: SN95 ET List
Haha. If it breaks it breaks, its just a T5.
RevJon
