someone school me on Aftermarket axels.....
Shawnsvtcobra
scarface said:
I have been thinking about it....Not sure yet what I want to do.
Get a decent posi unit,and some moser axles i paid a little over $300.00 for a set.
scarface
I understand that...I just needed to know what parts I needed.
scarface
For the posi unit and the axels?
Stopsign32v
If you are pulling the front tires off the ground type of launches those wont last much longer than stock ones FYI
scarface
I understand bro...I appriciate all of your input. I will probably redo everything in 31 spline...I just will have to save up a bit more now.
Roger that, I'm in the same boat.
When the blower comes, the axle's coming out for an upgrade. :chef3:
G_94_T
TN
Dalamar said:
FYI the stock axles are good to 550 TQ.
less if you'd doing super launches with slicks.
From what' I've heard swaping the axles is the way to go, but you have to get the inside part too, plus install, it's about 700 bucks last time I checked.
stock axles will NOT handle 550 ft.lbs TQ...i know from experience
95 BLOWN GT
michigan
+1 you definately want 31 spline axles and carrier. 28 spline will not hold up for long unless you baby the shiz out of the car.and who here doesnt drive their car hard?
That's what they're rated at!
AND i said right under that, LESS if your doing hard launches.
ya, 31 splines is the way to go.
scarface
I have every intention of leaving the line at 6k on the soon to be mine Hoosier quick time pros. (at least once :) )
scarface
well You know Ive done the whole engine mod thing...problem is, I didnt upgrade the suspension at the same time. 07 is the suspensions year :)
SO far I have done upper and lower control arms, Springs, and adjustable shocks.
scarface
OH, and if I wasnt good enough at breaing things on my car...Im not getting some of Truuble's old parts to help me break even more :)
that will help!
I kinda did the reverse, went through the suspension, then motor.
but I still need a blower :mad:
:drunk:
peasant99
