Speedo ?(not speedo gear)
Blk97GT
Since I got ny car the speedo and tach have never been acurate. My speedo sits at 35mph when the car is not even moving and when its off, tach sits at 2k, 60mph reads at about 130mph :laughing5:. Anyway, I changed the speedo gear near the trans and installed a new sensor with it, correct for the 3.73's in my car and there is no change so im gonna assume its a problem in the cluster itself? help me out people, wanna get this fixed. Thanks
all you may need to do is reset the needles.
assuming the cluster works properly.
For the tach, you'll need to find a code reader that will tell you what the rpm's actually are. This will not be the el-cheapo reader either.
For the speedo (after the gear in the trans is replaced) you can probably use a GPS to cal your speed.
