Springs???
94 DropTop
What springs should i go with for my car? I have weld prostars on the car now, and it needs to be droped a lil. I plan on a 28in tall tire in the rear with the ones on it now go bald. Im more conserned with 1/4 times than the way it looks so what is a good spring that will lower the front about 1.5 and with lower the rear maybe a lil more than .5? I was thinking about an eibach pro-kit.
94 DropTop
cuz everyone tells me they wont lower the car at . I would like the times but i want a combo of both. if the springs wont lower it ill spend my money else where on the car.
I would think some 4 cyl fox springs would lower the front decent, does anyone know how much lower those springs make it? They're supposed to be pretty good for launching when paired with some adjustable struts.
95-stang
I'm on Steeda springs, as you can see, the back is still a little high, might be handy if your looking at bigger tyres. ;)
stang94X
im sitting on steeda drag springs and you can see in th picture i have what the car looks like and my tires are 25" tall, but my car has also been stripped for weight reduction so that also make a big difference on how low or high the car sits
stang94X
this is the only pic that i could find at a some what of a side view, this was last febuary, same suspension and same tires has i have right now, but the only weight reduction that was done in this pic was no back seat, no spare tire and jack and in the front are aluminum heads, i'll take a pic of the car later of how the car sits with all the weight reduction that it has now
LAFENATU
You do realize that the car is not going to go as fast when it is lowered unless they are drag springs.
Example, Eibach Pro Kit vs. Stock Spring, the stock springs are gonna give you a better time.
-R
94 DropTop
I know thats why im looking for drag springs that drop the car. I want the car to look good so i might just get a pro kit
gt96stang
ever think about fox 4cyl front springs and cutting the rear coils??? cheap alternative and supposed to help with weight transfer..
