storing your stangs
Tony
ohio
i knw some of you drive your mustangs all year long but for those that stick them in the garage and store them all winter...what are some things you do to keep the car running right and looking right?
i hate going a long time w/o driving it or at least starting it. so i always try to get it out and drive it up & down the street a little. how long can ya let it sit before it starts to cause ya problems from not being driven?
Musturd
I usually just run my cars once a week or two . Then once the new season comes swap the plugs do my fluid changes, rad fuel filter the usual junk And run her hard for spring and summer
Nightmare
Cedarburg Wi
I get the car detailed and then stick it in the garage. I go by where it is kept about once a month and start it up and run it for 20 min.......that is all I really do.
Venom351R
Maine
dont start it and let it run for a short time. It will build condensation up in the engine and everywhere else. Just put fuel stablizer in it pull the battery out and call it good. I did not start mine from sept 2010 to july of 2012 and it fired and started on the first crank.
95riosnake
Pittsburgh, PA
I used to always pull the car out every couple weeks and start it up for a few mins but the past few winters I always end up with the car torn apart so much that moving or starting it isn't an option lol. Usually the first chance I have to start it is when the winter is over and I've finished that round of mods.
Venom, can you tell us more about why not to start it up?? I've never heard this one before and im curious....
Tony, here's what I do:
Storage:
#1) I wash the car entirely. I skip waxing, personally.
#2) I sweep the floor under the car and place a piece of cardboard under the engine, transmission, and rear diffy. This will allow me to see anything that may be going on (a seal is leaking, mouse droppings, etc.)
#3) I roll the windows up, I close the dash-vents, I stick a rolled up sock in each exhaust tip. (The windows are rolled up to minimize the risk of theft, as well as to keep the interior dust-free. The dash vents are closed to prevent any strange smells from entering the car and "brewing" into my seats. lol. Nothing sucks more than finding a skunk in your trash, spooking it off and having it "light up" your back garage area... Get back into THAT car after a winter of being closed up with skunk smell... lol. Finally, I stick the sock in each tip to prevent mice from crawling into the mufflers to build a nest.
#4) I place a chalk under as many tires as possible. I don't use the e-brake for two reasons: I dont want the brakes to rust together, and I dont want the handle to warp the rubber on my center console from sitting up for prolonged periods of time. Keep in mind when you chalk the tires to prevent both FORWARD and BACKWARD ranges of motion.
#5) I leave the transmission in 1st gear. (this too helps keep the car in one spot.)
#6) I max the oil level out on the dipstick. I don't over-fill it, as I will be starting/driving it. But I max it out in order to cover as much of the interior of the engine with oil as possible. This helps prevent surface rust from developing.
#7) I lock the doors, put on the cover and read her a bed time story.
#8) *IF* there will be a second car in the garage: I roll down the window on the door that will be "exposed" (not against the wall) ~1/8", place a full-sized beech towel in the window and close the door. By having the towel hang over the door it will help prevent door-dings from the other car.
Maintenance in storage:
#1) I start mine up (well, when the engine didnt knock LOL!) once a month regardless. I let it idle all the way to temps to open the thermostat and to circulate the coolant. I also give it some gas, even if its parked, to ensure the oil-pump gets a load-bearing run.
**NOTE: Test your coolant, you can buy a $4.00 tester at auto-zone. Nothing sucks more than too much water in the system and cracked block.**
#2) Colorado gets 300 days of sun, so I drive it (hopefully)at least once a month (this counts as a "start up to temps process".)
#3) I put Sta-Bil in the gas
#4) I put an excess amount of air in the tires (to help prevent flat-spots, also as the temps drop the pressure in the tires drop as well, and finally if one of the tires does have a leak this will give me the most amount of time to catch the leak before its sitting on an expensive rim...) -- I usually max-out the tire's suggested PSI (usually 44PSI - Our cars call for ~35 PSI)
#5) Check your battery's water level. If its low, add *distilled* water. clean the terminals, apply petrolium jelly to the terminals, and use the felt washers on the terminals. You may want to unplug the battery fromt he wiring harness to help prevent dis-charge from an exposed wire or something. You can also set up a trickle-charger on the battery periodically.
I rarely go through a whole tank of gas during the winter. I've never had an issue in storage, even with the battery.
Goals of Chris' anal storage process: (bow chicka wow wow)
#1) Prevent *mice* -- Mice move indoors during the winter. Good luck repairing a dash harness that was chewed through, good luck getting the smell of their shit and piss out of your carpet, and good luck hunting down every last dead body.
#2) Prevent rubber failure (more bow chicka wow wow) -- By cleaning the car (and putting tire-dressing on the tires) you are helping prevent dry-rot. additionally, by starting the car you are circulating the fluids on the hoses, seals, and gaskets.
#3) Prevent gasket failure -- By runnign the car to full temps, you are allowing the heads/engine block/pistons/etc.etc.etc to fully expand to "hot" sizes.
#4) Catch problems -- By sweeping the floor I can spot mouse poo (see goal #1) - by placing cardboard I can catch leaks - By letting it heat up fully I can moniter battery health, engine health, and electronic function (do my headlights still work? or did a mouse eat through that too??)
*OBVIOUSLY* my process is completely crazy. But I'm in love. and men do strange things for love.
Steve-Oh
39°57′9"N 75°9'48"W
If you have a problem with mice, I've heard putting dryer sheets inside your car deters them. Don't know if this works or not but just read it somewhere. Chris and others have covered most of the basics, seal up exhaust / stabilizer / car cover / pull battery or battery tender. I either store mine with the old wheels on it or put the car on stands to prevent flat spots on the tires.
Nacho98
I lay two sheets of thick mil plastic down covering the entire garage floor to keep moisture from seeping up through the concrete and causing surface rust on everything; you'd be surprised how soaking wet it gets under the plastic after 6 months.
I also just do an oil change and then add fuel stabilizer prior to filling the tank. I keep the battery disconnected, but I connect it and start it about once a month, letting it reach full operating temp. I let it idle for about 45 minutes. I also at that time blast the heat, the AC, cycle all the lights, etc. to keep everything working and less likely to corrode, and I turn the wheels lock to lock several times to give the power steering some action.
I used to put the car on jackstands for flat spots, but found that given the stupid shape of the part of the jackstand that actually holds the car and how it isn't shaped remotely to any frame rail on any car I've ever seen, I've found that sitting on jackstands for six months probably isn't a good idea--I've gotten a couple small indents in my frame from it. I also found that sitting for six months has not produced flat spots for me, so I no longer go that route.
Other than that that's really it. Just start it once a month to keep things moving and in use, otherwise leave it as is with fresh oil and fuel stabilizer. I do give the car a nice bath and throw some wax on it, just so that the dust that settles doesn't bond to the point after sitting for six months resulting in a nasty clay job in the spring. Makes the spring time wash really easy also. I also keep the windows up and doors locked. I don't put anything inside the car, but I've heard of the dryer sheets.
13 years doing it this way and no ill effects.
I inflate my tires to around 40psi to prevent flat spots and i put a car cover over it with a trickle charger on the battery. I used to start it and let it run but i heard that may not really do any good and maybe be worse for it, there are no problems with letting it sit for 6 months. most engine wear comes from start up so by starting it and not driving it around you're not doing it any favors. I don't even put gas stabilizer in mine, hasn't seemed to matter.
joekd
Ct
My car is insured year round so the winter storage is exactly same as the rest of the year, plug in the battery maintainer, done.
clark98gt
Pennsylvania
Lucky for me, my garage is heated over the winter so I just wash it and cover it up. It never stays that way for long since I always find a reason to tear it apart for something.
Nacho98
i think it would be weird to drive my summer toy year round
i actually kind of like the 6 month break from washing/waxing etc...already have enough work keeping the dailies nice.
Tony
Tony
ohio
yea i like only driving it in the summer too nacho...gives ya something to look forward to, lol. all these replies are def noted! good shit...you guys know your shit!
