supercharging my 95gt
supercharged 95
Ok first let me introduce myself, I?m mark and I?m new to this form.
I have a 95 gt mustang and I just picked up a Kenny Bell 2.1 Blowzilla /Flowzilla supercharger with a gt40 intake.
I still have to pick up a set of heads. Found a set, but need some input. There listed as street/strip pro series
Aluminum heads. 210CC runner size, 60cc combustion chambers. 2.02 1.60 valve size. Fully assembled, premium hardware.
I was looking for a 90mm throttle body adaptor but it seems like no one makes One for a 95 mustang. Is it worth me having one made or
will a 75mm throttle body adaptor work good enough. That Leeds to my next question regarding throttle body?s, 90mm or 75mm throttle body?.
I have a 90mm mass air And 42lbs fuel injectors. I was going to also change out my transmission to a T-56. Please give me your input ?
if you're going to do heads I'd spend the money on a pair that is proven and a quality piece. I'm also going to say 75mm TB is going to be large enough.
rz5.0
Great state of TEXAS
with those heads your going to have pvt issues. look into some afr 165's. 90mm to big 75mm will be fine.
upgrade your fuel pump. colder plugs.
supercharged 95
i just getting my fuel injectors.. which injectors are better, ford racing 42lbs injectors or Bosch Green 42 lb Pound Fuel Injectors?
toyman
I would check with KB to see what the Blowzilla/Flowzilla intake size is. The Blowzilla intake is only 70mm so a larger TB doesn't help. You just want to match the opening sizes.
Naptown_Stang
a 90mm throttle body i dont think will fit on a 95 nor is it necessary. It will hit the oil fill neck i think. 70 or 75 would work fine. Make sure those heads are fine and ready. any cams?
well unless you add the intake elbow the Flowzilla ends just like a fox body setup so if you ran that setup it would fit. the largest I've seen for SN95s is a 75mm.
ProKiller
PA
if you wanted a 90mm then it would be easier to do a fox conversion with that blower but a 75 is fine. i'm still running a 70mm with my combo and i'm pushing 500 to the ground. what brand heads are they?
supercharged 95
thanks for all the info. i only see three companies making 75mm throttle bodys for a 95. stack, bbk and summit racing. whick one would ou recomend
Professional Products makes one too, I like mine because it matches my polished Flowzilla intake but it took a little tweaking when i got it.
