Swapped updated NPI intake... themostat housing??!
Corbic
Ok, so I finished the NIP intake swap..
however my Themostat housing is not seal and doesn't line up properly.. it leaks all over..
what am I doing wrong, do I need a new one, different gasket? Where do I get one? Not seeing any on ebay.. nor summit racing.
SnakedMark8
The Tstat housings are different between the PI intake and non-PI. You need to pick up the correct one. The o-ring goes on top of the Tstat. Now I have seen some just RTV the daylights out of the housing, not recommended.
Jrgunn5150
Where did the intake come from? Is it a Ford piece? I didn't ever swap my T-stat housing, I may have been lucky or something though...
MustangMatt96GT
Yea they arent different pieces, but mine leaks slightly. Ive been to lazy to pull it off and fix it, being that the whole top end is coming off next month anyway!
reivaxtorres
ok, you swapped the NPI intake for another NPI one? if you did and you went from the full plastic to the aluminum crossover, the t-stat housing is different. you need to get the revised one.
if you went from plastic NPI to aluminum PI, then the same thing applies.
if you went from aluminum NPI to aluminum PI, then you shouldnt be having a problem, the t-stat housings are the same.
if you went from a ford manifold to a dorman manifold, the housings should be different, but i dunno. i know there is some kind of adapter thingy that the dorman one uses, but ive never worked on one before.
C
Corbic
I went from NPI Plastic to NPI revised Aluminum.
Where do I get the new housing from?
MustangMatt96GT
are you sure the housings are different? Cuz mine seems to work, but maybe thats what is causeing the leak. I went from Plastic NPI to Aluminum PI. Anybody know the part number?
Jrgunn5150
I went from plastic NPI to alloy PI, didn't swap em, so I couldn't tell you at all.
reivaxtorres
yup, you get it from ford. dont know the part number, but ask them for one for the revised manifold.
C
Corbic
Its a Ford part...
there is no revised thermostat housing per two ford dealerships...
Does the red-rubber-ring (gasket) just sit on top of the thermostat then and is pressed down onto via the housing? As apposed to sitting on the plastic of the old intake?
voidfinger
i was about to say, i never had a problem swapping my npi to an alloy npi "dorrman" one and then to a alloy pi "ford"
Jrgunn5150
I was wondering what in the world you guy's were talking about, I know I never changed my T-stat housing, lol.
So what was the problem?
