Swaybar Endlink????
reldapimp
My Front Sway Bar end link thing that connects to what I believe is the lower control arm???? Is not connected and seemed to have snapped a bit off the control arm itself..
What are my options I dont want to replace it with the stock crap...
Paul
You can get some urethane replacements from www.stangsuspension.com
They are one of our sponsors, and you get a 5% discount if you use the SN95DISC code upon checkout. I just ordered some endlinks and other bushings from them last week and they arrived promptly.
Paul.
R
reldapimp
The problem is... It also broke a little square peice off the lower control arm... So... I also need new control arms...
Might just go with stock stuff again while I save up for maximum motorsport kit..
Paul
What little square piece? Do you have aftermarket control arms?
If you are getting New control arms Get the 03 cobra A-Arms,is a nice yet not expensive upgrade for tour cars and as for the sway bar links the Energy Suspension Sway bar link are fine.
R
reldapimp
My control arms are stock...
When I say little square peice.. The endlink seems to have ripped a chunked of metal off of it in the shapre of a square..
Thats the reason I need a new control arm...
Paul
The endlinks pass through a hole in the control arm. The control arms are made of really heavy gauge stamped steel. I can't imagine the endlink could damage it. I wonder if you're looking in the right place. Do you have a picture of the damage?
2slo95fiveoh
Lawrence, Kansas
X2. that sounds like some freak accident, but i supposed possible. pictures would help..
R
reldapimp
Pics tommorrow.. But I know the part the endlink passes through..... There is just a big chunk of metal missing on the control arm(where the endlink passes through)....
purplehaze
i just purchased the endlink kit from energy suspension, but wanted to get the bushing as well but dont know the size of the stock sway bar. does anyone know the size or have a part # for the bushings? thanks
Paul
The Stangsuspension website lists all the different swaybar bushings and their applications. You just need to peruse through them and pick the one for your car.
