T-5 Bullet Proofing
94kingcbra
So I am looking to upgrade my T-5. I have seen kits but I cannot remember where. I am looking for something where I can just take my car to a tranny shop, I will give them what they need so they can pull the tranny and completely rebuild it with parts that will will be much stronger than stock. Also looking to uprade to a 26 spline and a new clutch. The whole reason behind this is because I am grinding gears even with the clutch all the way in, yet my clutch is not slipping. Any input would be great. Thanks!
Jrgunn5150
I can do it for you, depending on what you really need I may or may not recomend it for you. I'm guessing from your sig you are pushing around 400 rwhp? What kind of driving do you do? Just a fun cruiser? Launching it at 5k on slicks?
D&D performance and Astro performance carry the kit's you are looking for though.
94kingcbra
Yeah about that much, but down the road I want to supercharge it and make upwards of 500...So I figured if I was gonna get it fixed now, I might as well be prepared
95 svt cobra
yeah just do some online searching, hanlon makes good products as does TCI automotive. pricey but good products
Jrgunn5150
In that case, I would recomend a Tremec now, and just be done with it.
Also, even though you have the clutch all the way down, your cable is probably worn and stretched. If adjusting it doesn't work, replace it, and only replace it with an OEM cable, no adjustable cables or aftermarket cables.
sk8inrj1
Where you get OEM FORD clutch cables other than the dealer. I've heard that the dealer charges like $150!
ryclef331
I run a G-Force T5 in my car and LOVE IT. It was built by astro performance.com...they no longer sell g-force kits BUT they do have their own t5 gear set now that is just as good if not better. Tony's customer service is second to none at astro. I've driven a couple of tremec and tko cars and while the tranny is strong, it did NOT like the way they shifted...felt TOO notchy. I love my gforce....
95 svt cobra
yeah i agree on the scratchy shifting, that all but went away though when i started running synchromesh, its ALOT smoother, at least when the tranny warms up a bit
ScottyDsntKnow
Bah, the TKO series of transmissions are fine. So what if they're a little notchy, just make sure you have a shifter with properly adjusted stops and bang away.
I just put 3 fresh quarts of synchromesh into my 3550 and it shifts pretty damn smoothly right now compared to how I remember it.
IMO you can do all you want to a T-5 but in the end you still have a small cased T-5 with small gears. I'll take the big beefy gears from a Tremec any day.
Jrgunn5150
The case is the reason I would recomend the Tremec too. Once you get the Astro full kit, and pay someone to put it in the trans (preferably someone reputable, not billy bob's transmissions, or AAMCO), you're nearly at the cost of a new TKO 500.
IMO, piece of mind is worth 4-5 hundred to me.
fastgtfairlane
check out www.astroperformance.com and www.gforcetransmissions.com you can buy built transmissions from both. i like the gforce kits. you can get straight cut gears and dog ring kits instead of syncronizers so you can shift without the clutch. either t-5 will hold up and it will be less work to put one of those in cause it is a t-5. each one has advantages and disadvantages. the t-5 is a little lighter than the tkos and will absorb less hp than the tko.
Mustang68
I definitely agree with astro gears kits.. everyone ive pretty much talked to about upgrading t5's have recomended their kits over others.. them and richmond gear are the 2 main ones..
ive always wondered.. what all is involved to swap out the t5's to go to the TKO's? i know ya need the trannys and possibly another driveshaft.. but other than that what else would you need? computer? wire harness? ect ect? or they just swap in like theyve always been there?
ScottyDsntKnow
Go do a search on the corral. Its been covered 100 million times over there. And no, the computer has nothing to do with anything where a 5 speed is concerned.
fastgtfairlane
ScottyDsntKnow said:
And it'll blow up sooner than a TKO as well. Like I said, small case=small gears.
this can all depend on the drivers shifting ability too. dont get me wrong im not dissagreeing with you completely that the tko is a overall stronger transmission. however with the stronger and beefier internals the t-5 when it is correctly built can handle just as much power as the tko. its just like the c-4 against the c-6. when built right the c-4 can handle as much power as the c-6 and it is lighter and has less rotating mass.
Jrgunn5150
You need a bellhousing, crossmember, or mod yours, shifter, and possibly a clutch depending on the version. Total cost, all brand new is around 2300 for a 5.0 (i'm not entirely sure) They sell used all the time.
I agree entirely, but most people can't shift a pro-shifted T5 properly, hell, most people can't shift a regular T5 properly, regardless of what they think.
ScottyDsntKnow
^ Agreed. On the other hand, it is VERY hard to miss the infamous 3rd gear with a TKO style tremec and a good shifter. Some people complain about the 1-2 shift being a pain in the ass. I agree that it is at first, but once you get used to it just rip the 1-2 shift hard and it'll go right in. Not like you're gonna hurt anything with a properly adjusted shifter stop either.
I remember reading a Tremec ad once. It said "if you're hand isn't hurting you aren't shifting properly". lol.
fastgtfairlane
i have never driven a car with a tko in it so i have no idea how it shifts. i do like the the gforce and astro t-5s though.
Anrev
I got to drive an 87 with a t-56 in it not too long ago and it felt AWESOME. Thats what Id like to get.
