Teardown has continued
humjaba
Hey,
So I've been slowly working on getting stuff together for a PI swap. Long story short, I now have a complete 02 GT motor. I got it for $100 from a friend :D He said it made a ticking noise and had low oil pressure after warming up. He thought it was a spun rod bearing. Note the broken chain guide in the second pic- the rest just came off (didn't have to loosen the bolt to get it off). Could this cause his symptoms?
Anyway, I got my hands on an impact gun the other day so I had some fun getting stuff apart tonight. What do you guys think of the condition of this head? (I'll post up pics of the other one when I get it off... gotta figure out what to do about that oil spilling out)
Jrgunn5150
The timing guide would cause that, yes. As for the head's, they look like they need a tanking, and pressure test at least.
H
humjaba
Alrighty thanks. They should be fine then, considering the car ran perfectly before the ticking sound began?
voidfinger
looks good to me, the heads look in good shape... not a lot of carbon or ash.
H
humjaba
Cool thanks for the help guys. I know I can use carb cleaner on the intake ports- will that also work on the under side? (sorry, i'm not up to date on all this technical jargon)
voidfinger
the poor boy's way to tell if the valves are ok and the seats are ok is to put water in to the ports and see if it runs out around the valves... also, you could fill it with carb cleaner and let it sit to take deposits out.
Jrgunn5150
Oven cleaner will strip nearly anything, as long as you have a big enough tub, and no small pets around. You'll need to scrub a bit, but no big deal. I need to scrub stuff that comes out of my part's washer too, no matter how long I let it bounce up and down in there.
voidfinger
yea oven cleaner does a number on carbon too. but with that tub does it need to be 100% oven cleaner?
Jrgunn5150
I suppose you could cut it, I just never do, the real stuff is pretty cheap funnily enough, lol.
voidfinger
its just that most oven cleaner is in a spray can.. so that would suck to fill a tub with about 20/30 spray cans lol.
Jrgunn5150
I'm talking about the old school, real oven cleaner, it's purple, comes with a warning not to get it on your skin, lol.
voidfinger
all of it that i've seen says not to get on your skin... the kind in the can i used started melting the yellow gloves i was using...
but are you talking about purple power??
voidfinger
yea its ok, but its still not oven cleaner... watered down purple power is what you use to get an interior clean. :) worked like a charm.
H
humjaba
So I have a 60 gallon rubbermaid tub... could I just pour this crap in there and soak each head in it one at a time? Parents would never let me use the tub in hour house :p
Jrgunn5150
Yep, :thumb: No0t Purple Power though if it's not oven cleaner. Just real liquid oven cleaner.
nyuk98gt
Hey, are you guys sure that you want to use oven cleaner? It is usually sodium hydroxide and works well on enamel surfaces (like the inside of an oven) and is OK for iron heads but it will corrode aluminum. I would cut it with plenty of water or use an aluminum-friendly degreaser. Don't want to cause undue alarm but it would be a pity to mess up your heads!
Chris
