cheebs127
What did you do for brake lines? Also, how did you drill your holes for the down bolts on the rear brackets?
Good job so far man, this thing is really clean.
I had the brake lines from the donor car that I used. To keep it simple and because i suck at flaring new lines. I bought an abs delete block and I'm using all the lines from the donor car.
For the bolts I drilled straight up into the trunk. I think they're 1/2 bolts with a steel plate inside the trunk to disperse the pressure from warping the trunk floor. If I had a welder I probably would have just welding the darn things in there. Would have been easier and faster.
