Throw out bearing or input bearing?
sn95jones
Arlington, Tx
So as y'all know I just recently did a full clutch job on my car and it's squeaking now. It only does it when the foot is not on the clutch the moment I engage the clutch it will stop or if I lightly hold my foot on the pedal it will stop. It's VERY annoying and I wish it would STOP!!
It doesn't squeal, it's just a squeaking noise kinda like a squeaky pulley, actually identical to it.
Sent from my SGH-T989 using Tapatalk 2
ivan12
Throwout, did you replace the old one? Do you have an aftermarket quadrant or firewall adjuster?
TLSF150
My car made a squeaking noise after I put a clutch in and it ended up being my clutch fork.. the cable was just a little to loose and let the fork move causing the noise.. the fact you said if you barely put your foot on the pedal and It stops makes me think you may have the same problem..
But if it aint the fork its definitely the throw out bearing
Sent from my Galaxy S3 using Tapatalk 2!
LilRoush
In your TV
I just had the clutch/bearing done on my car. About 20 mins into driving it I got that same cricket chirp/pulley going out sound when I touched the pedal. Check your trans mounts. I found out the shop put my old ones back in when they needed to be replaced.
sn95jones
sn95jones
Arlington, Tx
Well the clutch fork is worn I know that but finding a clutch fork is impossible nobody sells them anymore and LRS has them on back order. :-(
white95
Apex Junky
Prairieville, LA
How the hell is that being an ass? Please do point that out.
Jones.. Don't start with me, today isn't the day. However, I will answer your question.
Ivan asked you a question related to the OP to get some more information on the topic. Instead of just sayin, "yeah, I used a new one" you quoted yourself which insinuates he didn't read the first post. That was being an ass in my book. Lots of people mistakenly reuse old parts if they're in a hurry. Honest mistakes happen.
sn95jones
sn95jones
Arlington, Tx
I did the clutch job on my car so no I did not use old parts.
sn95jones
sn95jones
Arlington, Tx
Okay wow and your the one calling me the ass? **** off dude I never said I did a perfect job but I followed everything step by step.
white95
Apex Junky
Prairieville, LA
Yes, I called you an ass. You are an ass and you know it. As for telling me to **** off, I'll give you that one for free.
Musturd
Powershift inside with the car off and make engine noises and see if it makes the same noises ....
sn95jones
sn95jones
Arlington, Tx
Maybe you need to step away from the computer before you get too power hungry, all you do is scare everyone with your ability to ban people, get off your high horse banning someone because you've had a bad day? Yeah im sure that will go over real well this is my thread I asked for help not your smart ass remarks and your attitude. You want to help and give advice towards my issue then fine but leave your attitude at the door.
white95
Apex Junky
Prairieville, LA
jones.. No one is going to ban you, I'm not power hungry and you are off base with your assumptions.
96GTPlanB
