tires and clutch
95BlkCobra
pasadena california
ok so i need new tires and im looking at sumimoto htrz2's for 100 ea. plus 45 for allignment which comes too 445
or hankook k110's for 104 ea plus 40 for allignment which comes to 461
as far as clutch im leaning toward the king cobra, now my question is does it come with a frpp tob?
total with install would be 372
your guy's input please
Win
Kennesaw, Ga
What size Tires are you looking for???
On the Clutch Install what are they quoting you for the labor portion of it??? Does it include any other services ???
95BlkCobra
pasadena california
well i dont pay normal cost on tires, i get them through my shop so i pay way less than what the average joe pays. as far as the clutch i just want soemthing better than stock. damn throwout bearing keeps going out
Win
Kennesaw, Ga
blah blah blah i dont pay normal cost on tires!!!!! That's fine i can go online and get the tires i had that are Hankook Ventus for 80 shipped 255/45/17 Z rated.... If your TO bearing keeps going out you have a Pre existing condition then !!!! I am about to install a SVE mongoose clutch with a Fidanza Alum Flywheel and a FRPP driveshaft.
95BlkCobra
pasadena california
well ive had 2 TO bearings put in by two different transmission shops and the have both told me my clutch doesnt look bad but the most recent was 2 years ago so now that its going out again im just going to replace the whole thing.
as far as tires i wasnt trying to brag just replying to onyx's post. just want ppls opinions on the choice in tires and clutch. im leaning more toward the sumimotos. ive heard they are better than hankook...
Win
Kennesaw, Ga
Tires i would probably go with the Ziek 912 for 97 a tire. It is a all season tire so you will get a good medium. there have been people here that say the FRPP TO bearing is good and bad. Normally a clutch kit comes with a TO bearing
Win
Kennesaw, Ga
95BlkCobra said:
yeah it comes with the TO bearing but is the the frpp TO bearing or a normal Ford TO bearing they threw in with the kit
Its hard to say your getting an actual KC clutch these days. Most clutch's are made by Sachs anyway. Supposedly the KC clutch has Brass Rivets (unsure of that).
94Snake
Valdosta, GA
do you have a manual adjust clutch cable? is it too tight? if you still have the auto adjust cable maybe it's time for a manual one. is the input bearing retainer on the tranny getting galled up? also don't forget to do the pilot bearing and turn the flywheel and swap out the leaky rear main seal.
also that KC clutch setup is not a heavy clutch. to me, that clutch is a stock replacement item. as for the bearing being frpp, i seriously doubt ford specifically makes a beefed up TO bearing. it's probably just stock ford along with that clutch disc. the only thing good about the kit is the pressure plate, and that's because it takes less pedal to engage/disengage.
wannaboost94gt
I just ordered a KC clutch kit for 160.00 off a reputable corral dealer. You want his contact info? It'd save ya 100.00...
wytstang
Sumi's are the worst tire I have ever purchased. I whole heatedly regret paying for them. The rear fish tails way to easy on wet roads for my liking. In about 5 or 6 weeks I will be ordering BFG KDW 2's or Nitto Invo tires to replace mine. Both (as per reviews) work great in dry/wet conditions, BFG's seem to have a slight advantage on wet roads [very marginal though]. Nitto's seem to win in the quit category.
F1atlander
Kennesaw, GA
might as well get the revise throw out bearing retainer ($40) and as for the clutch.... i called gene evans ford to get a price on the KC and its close to $300 now. i went with the ram HD, i should know how it is in a couple days
94Snake
Valdosta, GA
i've been running sumitomo since 2005 and i've never had an issue fishtailing in the wet weather and i've driven this car from south GA to Wichita Falls, TX and to WV on several occasions, not to mention FL and SC.
maybe it's time you updated your suspension or driving style.
wytstang
Driving and suspension are fine, they are just crappy tires. "You get what you pay for" and I got exactly what I paid for.
jthorn9
As far as tires go I'm running Nitto Extreme Performance tires, very good bang for the buck tires. They handle very well in wet and even icy conditions and seem to hold up fairly well and aren't as noisey as similar priced tires. Good deal on the clutch but why not look into a stage 1 spec or basic centerforce?
