Tires
Cocomojo
Looking at finally getting some decent tires and fishing for suggestions. My best mate had Goodyear Eagle F1 's on his SC400 and loved them and I am thinking about getting those. Any suggestions would be most appreciated.
Matt94GT
I LOVE my BFG Gforce KDs. I will deff get another set when these go. You can get the KDW series if you do a bit more wet weather driving.
Lots like their Nittos but they arnt that good at all in the rain.
MeanGrn Gt
i have kdw and they are a great tire. I have heard good things about nittos too. I dunno what size you want but i think http://www.discounttiredirect.comdiscounttiredirect.com had the nitto 555r's in 245's for pretty cheap (107 or something like that). i believe the f1's are the most expensive tire in the same class but are a good tire. i got my kdw for 144 and i think they have went down in price on there site too.
95CALI-5.0
I also have the BFG KD's. THey stick really good in the twisites. They are a bit pricey though
r_suh
had some dunlop sp 9000 on my 18's and currently i'm using yokohama es 100's. both are great
Ender
I'm running ES100s as well, they are a great tire. Very reasonably priced and they give good grip wet or dry.
G_94_T
TN
Im running kumho ecsta 711's....they're a cheap tire and i found out why....no traction wet or dry,so this will be my last set
Lightning Struck
Ive ran those too before, just didnt hook well enough to continue useing them :-\
C
Cocomojo
One more question on tires. I think I'm going with the BFG, now a question of size. I have 17x9 wheels front and back. Should I go with 245/45/17 in the front, and 275/40/17 for the back? or just go with the 245 all around? Don't mind my ignorance on the issue I'm going from buying 31" tires for the truck to buying stuff for my new love.
blackfang
My professional opinion working as a Apprentice tech, A Tire salesman/Rep for Michelin/BFG and now working for Toyota, that 245 is too narrow to put on the 17x9. Will it fit? Of course
Will the tire last? Most likely not.
Save yourself the $$ and go with a 255 or higher
G_94_T
TN
a friend of mine had 275 at all four corners and never had any clearence problems.He now runs 315/35's on the back,this was on a stock height '95.
245's really should not be a consideration. Much too small for a 9" wheel. Seems dangerous to me and would look like azz. A lot of people go 275's at each corner with your size wheels and are OK. If you drop or are dropped, you may have a rubbing issue. You'll just have to do it and see. If so, plan on getting some wheel spacers - you won't need much, probably no more than 1/2" to clear and get your turning radius back.
I've heard of a lot of people just dealing with the rubbing, since it only happens at low speeds like in parking situations.
mattn03
