track times!
1quk50
so whats everyones best?
and with what mods?
mine is a 14.33@93 with a 1.98 60 ft. street tires,full exhaust,70mm tb,elbow,1.7.1 rollers,pullies,cai, 3.73's, built tranny,short throw..
so far thats my best.
19mustang95
11.57@117
highest trap was 121. bad 60' because it was the first time at a different track, but the track had a much better top end...
car would have gone 10's with the new gears, bigger jets, and JLT i had just put in. never got to spray her again before the accident. :crying:
96 Cobra - longtubes, o/r H pipe, flowmaster catback, 4.10s, rear eibach drag springs, 175lb MMR coilovers, lakewood 70/30 struts, lakewood 50/50 shocks, tubular k-member, tubular a-arms, 15x3.5" centerline telstars, 155/80/15 BFG Goodrich, 15x8" Centerline Telstar, 26x11.5x15 ET Street, NOS 100 Shot (55,37), Steeda UDP, MM 3-bolt CC Plates, a/c delete, ABS delete, rear seat delete, kirkey drag seat, taylor battery relocation, Stock intake w/ UPR Filter, IMRC Deletes, King Cobra Clutch, No front swaybar
Hopefully, sometime by the end of 2009. The entire setup will be in a foxbody with more suspension work and weight reduction. :coolsmiley:
Gus98GT
14.0 @ 98 :thumb:
3.73 Gears, CAI, X-Pipe, Flowmaster Catback, Steeda U/D Pulleys, Timing adjuster,
1quk50
14.0 nice.. if i could ever figure out the miss in my car! i would love 2 see a 13.90... but until i find it im stuck with 14.30's
jEEd
not really the drag kinda guy but when i went with some buddies this was my time
14.09 @ 99 with i think a 2.1 60'
Killercanary
I spent some time on the track, here's a quick rundown:
1995 GT convertible 5 speed
Stock:
------15.2 at 90
Above with ASP pulleys, offroad X pipe, flowmasters, HD clutch, nitto 245-50-16 drag radials, 3.73's, edelbrock performer intake, home-made CAI, 65mm FMS TB, bumped timing, and FMS shorty headers:
------13.8 98.55mph
Above with AFR 165 60cc heads, FTI custom cam, 24lb injectors, 190lph pump, 1.6 FMS rockers, dynomax mufflers and 2.5" tail pipes, 4.10's, an EEC tuner, and 315-35-17 nitto drag radials:
------12.5 at 109mph
Above with 26x10.5x16 ET streets, tubular K member with coil overs, adjustable shocks/struts, shortbelt, bogart skinnies, lightweight seat:
-----12.03 at 112.5mph
I'll have new times this weekend with my 9:1 Dart block 331ci with AFR 185 comp heads, probe shaft mount rockers, 1-3/4 long tubes, 3" into 2.5" X pipe, 30lb injectors, and an AEM stand alone.
95SC
11.34 @ 122.66 mph, 1.55 -60'
03 Cobra powertrain,new times with 100 shot coming in spring of 09
jc95gt
14.4 @ 97.82
60' was 2.3 (due to blown rear spiining one tire) street tires as well
has stock 2.73 rear gears
MODS:
Full Bassani Exhaust
Tremec Extra HD transmission
Hellion94
Peter said:
13.3@115mph with just CAI and flowmasters
You went 115 mph in a stock fox body with only a cold air and flowmasters?
I'm a little doubtful of that.
reduceallpain
GOD i'd love to have a terminator drivetrain in my car!!
My best was a 13.42 @ 102 with a 1.85 60ft
Mods are BBK shorty headers, Bassani mufflers, X pipe, bbk cold air intake, bbk 65mm throttle body, 3.73s, 14* timing, m/t et streets at 11 psi
justinschmidt1
went 12.8 @ 113 with npi, pi intake, bolt ons, procharger p600 at 10 psi, auto, street tires,turd trans.
Got my trans rebuilt with like a 3600 stall so it should be a differant story next time out.
