trans swap
rz5.0
Great state of TEXAS
i just wrecked my 95gt. i found a replacement but its an auto(not purchased yet). so if i was to put my t5 in it what would i have to swap over. computer,trans, flywheel, clutch, some wiring not sure what yet? anything else how hard is it.
LAFENATU
iirc..
T5 or Tremec
Bellhousing
Shifter
Shifter Ball
Flywheel
Flywheel Bolts
Clutch Kit
Clutch Fork
Clutch Cable/Quadrant
Lower Shifter boot
Uppser Shifter boot and bezel
Clutch/Brake Pedal Assy
PCM
Tranny Wiring Harness
Dust Plate
Driveshaft
Tranny fluid
Mika
The std has an added piece to the transmission hump in the floor so you might have to cut out the floor some. There must have some clearance issues for the std as opposed to the auto. i went to auto from std and it caused some fitment problems with finishing the interior but you shouldn't have these problems with your swap.
rz5.0
rz5.0
on fox there is a diffrence in wiring to the pcm in autos and 5 speed car. is there any diffrence on sn95 or is the pcm plug and play. would i just be able to beat it with a hammer for clearance or do i have to cut.
Mika
I'm not sure beating it will work, but you could consider using what you need from the wrecked car. Take a look at it when you start taking it apart. I'm not sure about the wiring I haven't gotten to that part of my build yet.
