Transmission Leak
koshe2
I have a 94 convertible with a 3.8 and an automatic trans. The issue is after the car sits the trans leak from the bottom of the trans dipstick. Normally not a big deal till I looked a little closer at it. I see where it attaches to the transmission bolt, but not sure how best to tackle this. Does anyone have any suggestions? Drop the exhaust is what I am thinking. Its a tight fit to get access to that bolt from the top.
New York
The bracket is on the bellhousing bolt correct? You should be able to get it from the bottom with a long extension and a swivel socket. Then wiggle the dipstick tube out. If it’s stick some times I used a pry bar and hammer on the flange. Pull the dipstick out of the tube so you don’t accidentally bend the end of the dipstick
