trickflow stage one
95opal
Like stated already dont bother with a cam and stock heads to much time and money for very minimal gains. Always measure for pushrod length no matter what, even if someone has the same combo... tolerances are always a bit different from one setup to another.
Win
Kennesaw, Ga
auto_x5.0 said:
I bought my tfs 1 cam used, worked out perfectly fine for me...paid $80 for it lol
Probably just like the Cobra Upper and lower you say you have on your car in your sig. Your now selling it cause you never put it on the car. You probably never put it in the motor.
auto_x5.0
Hey smartass, yeah the intake never made it and I didnt have the cam in for very long because Im selling the car so before you call somebody out think first.
Win
Kennesaw, Ga
You need to look into a Anderson Ford Blower cam for that setup. You will benefit so much more then a simple TFS1 cam
det_riot
Dearborn
I just picked up an n412 rom glueyes and he even though its a non blower cam, he still made approx 540 to the wheels on his 331
Win
Kennesaw, Ga
AFM cams are a great cam. It all depends on what your motor is and the specs of the cam. Just b/c someone made XXX numbers doesn't mean anything unless you have the exact same build. The B cams for instance with a Stock Cobra motor stock pistons and since the cobra has 1.7RR the B21 is the perfect cam for a blower application.
You also have fast as cast heads. The n412 was designed to be used with those heads.
