Magic
94Pro-5.0 said:
Good link!
For a $100 more you can get the set of staggered sizes 18x9 and 18x10.
I say if you can save up for them, get them!
94Pro-5.0 said:
SRT Handz said:OnyxCobra said:SRT could you please explain how 17" wheels make the car lower? Doesn't make sense to me when the tire you're riding on is still the same diameter on both rims.
18 inch wheel are 1 inch wider that 17s, thus the car will sit up 1 inch higher on 18 inch wheels opposed to 17 inch wheels.
Compare me and Reds cars, Look how little ground clearance i have under the car compared to his.
17 inch tires arnt the same diameter as 18 inch tires, that why 17 inch tires wont fit on 18 inch rims :santa_grin:
94Pro-5.0 said:SRT Handz said:OnyxCobra said:SRT could you please explain how 17" wheels make the car lower? Doesn't make sense to me when the tire you're riding on is still the same diameter on both rims.
i see what you are saying. the difference between the wheel hub and the ground on a 17" wheel is 1/2" shorter than
that of a 18" wheel. but SRT Handz still has a point. A buddy of mine used to have a SVT contour (lowered 2"), and with
his 18s on it, it fit really well, with minimal wheel gap. he put the stock 16s on for winter, and it was so low to the ground
he had to put the 18s on.
actually, 18's would only sit 1/2" higher than 17's, becasue its 1/2" is of the larger wheel is in the wheel well and the other extra 1/2" in under the car (don't really know how to explain what i'm tryin to say....) but yours is only a 1/2" lower
Red said:My 18s are almost exactly the same height as my stock 16s. Handz car is just lower, rim size doesn't have anything to do with it...
Haha your car is only lower to the ground because of your suspension, not your wheel size.SRT Handz said:OnyxCobra said:SRT could you please explain how 17" wheels make the car lower? Doesn't make sense to me when the tire you're riding on is still the same diameter on both rims.
