Re: uncltrvlnmatt's Build Thread 1966 Coup 4.6 DOHC Build Up. Updated 6/15/08 Pics
I was unexpectedly able to get about 4 hours work done today. So I removed the spaghetti from the engine compartment and tagged the harnesses, removed upper and lower cowl, removed wiper motor and pivots, removed cruise control module, removed horn assembly, basically the only thing left is the A/C lines, receiver dryer, clutch cable, and brake booster. I need to get the tool to disconnect the A/C lines and fuel lines.
We also removed the dash board. I suggest that if you don't absolutely have to do it, don't. What a wiring mess. But there are only about 11 bolts that hold it in place.
Here is the cleaned out engine bay.
Here is the wiring mess under the dash board.
This is what the asshat saw after he rolled his car.
Right side fender well Empty of wiring. The harness that is still connected goes inside the car, now that the dash is out I can remove it easier. (I hope!)
Left side fender well.
Front of the engine.
