Universal Cut to fit Plug Wires?
NERD
Virginia
The only set I think I've found was for MSD wires but the description isn't clear.
Do they make a cut to fit wire for the 4.6? Last year I ruined a perfect set of wires trying to cut and trim them to fit better. Now since my wires and coils are under the intake manifold I'd like them to be a lot shorter.
If they do make them, can you find me a link?
Thanks,
Mike
:icon_salut:
NERD
NERD
Virginia
The only thing I'm seeing there is pushrod universal wires. Did you post the correct link?
GDawg
Wait a minute... I meant these...
http://store.summitracing.com/partdetail.asp?autofilter=1&part=MSD-31189&N=700+4294925143+4294756594+115&autoview=sku
largeimage.asp
BlkoutGT
MO
Does someone like Ford Racing make wires for you (4.6)? Because Paul made a write up in the "how to" section of how to cut and loom your own wires. And the Frpp ones arnt supposed to be cut to fit, but with the right tool its easy.
joekd
Ct
I bought the FRPP 9mm wires for my 4.6, they are longer then OEM motorcraft wires but still a perfect fit with no trimming needed
NERD
NERD
Virginia
I'm special, My coil packs are under my intake manifold.
joekd
Ct
Which is why I mentioned that the wires are longer. If yours is that much of a cutom setup then I doubt any precut kit will work.
NERD
NERD
Virginia
I think one of us is confusing the other.... I don't want a precut/sized wire kit. I need to cut and assemble my own wires which is why I said I'm looking for "universal".
My plug wires at the longest point only need to be about < 12" long.
GDawg
sxynerd said:
joekd said:
Ahhh..then it was my misunderstanding
Thanks for the help though, I'm still looking.
I use the precut MSD Superconductors. Excuse my ignorance but why won't that second set of wires work? Specifically...
They look like the long ends will fit the spark plug holes and the elbow ends would fit the coil packs. What year's your car?
Paul
Just buy a new set of terminals, cut the ends off your existing ones, and reinstall them.
