ok...so here's the deal so far. it's a roll cage shop that so even though it's messed up on them...I'm not holding them to it because they don't have the ability to do it. stanger banger...we've met before so if you pm me your # we can talk more. ok so the car....checked inertia switch and it was fine, car seems to be getting fuel....not spark, pulled a plug wire and put another plug in it...didn't get anything. the msd ignition box is getting power....BUT seems that where it supplies power to the coil it loses it where the wires splice out to the coil and to the factory ignition. if you guys are following me. Car has a new dizzy, new coil, new ignition module from the issues i had before. they said that it died mid moving it around after running for about a minute. I had this issue before where it would do that. replaced the dizzy after the coil and ignition module and it was fine for a few months till now. I'm not sure where else to go with it. when i hook up the factory ignition to the coil and take the msd box out of the equation still no start. I'm thinking i might just remove the msd setup completely as it didn't make a huge difference anyways. i'm not making huge #'s or anything. if i do that...it's just connecting all the factory ignition back up and finding the issue causing no spark and it should be good hopefully right?
