Upgrade dilemma here
O
optionizerSS
Pittsburgh, PA
A used vortech would be the easiest and most effective way to meet your needs. The gt40 crap is going to be a huge disappointment.
Don't think I'd want that. Never had one and not that familiar with them but think the cost and labor would be as much as H/C/I? I'm an old school hot rodder. Big cams, high flow heads and big carbs. I know technology has changed but I'm still a basics kinda guy...lol.
if you got a solid used kit it would not be a whole lot more $$$$ or time installing but would get you much more reliable power.
95opal
You can literally be up and running in a couple of hrs. Youll be into a gt40 set up with a cam for same price but wont come close to the HP numbers an S trim will give you.
I get the big cam ect thing but realistically a gt40 combo wont hold a candle to a blower.
Wmac
Steeltown, Ontario
If you only do a mild build, a custom or canned tune may not be required. Also, the explorer injectors flow around 21# and will work with your current mass air.
That's what I use with a stock W4H0 ecu. Only issue is cold start-up enrichment. Runs lean until the ecu goes into closed loop.
Rons95GT
Not a new member
What would you prefer it said?
No other preference from me for ttocs. I think it is appropriate, I didn’t mean anything negative. I thought it was funny. He has good info. I guess I’m not chatty enough. I’ll be a new member for years.
so ya think I am a whore, or know it I guess? :) guilty
