I am purely speaking from my personal experience here with my choices of IRS bushings. I bought my cobra and realized that I needed to get rid of the stock IRS bushings that were on the cobra. I think we all can agree the stock rubber ford bushings are junk.
I disagree that the stock IRS rubber bushings are junk. For the cobra owner that never goes to the track and wants the smoothest possible ride with least amount of NVH, the factory rubber IRS bushings are the best option; As bushing stiffness increases, the ride quality will suffer and NVH will go up and only a retard would disagree.
For performance, the 99-01 IRS bushings are quite soft, but the 2003-2004 Terminator factory rubber IRS rubber bushings are 400% stiffer than the 99-01 versions, so they are not to bad for performance.
A 2003 Car and Driver Terminator road test proving that the factory IRS is pretty good right out of the box with the stock IRS bushings. Remember that Car and driver guys road test a ton of cars and they gave the terminator very high marks in the handling dept. The 2003-2004 IRS bushings certinely are not junk.
http://www.caranddriver.com/reviews/2003-ford-svt-mustang-cobra-road-test-review
Car and Driver article
"Of course. But it wouldn't have been as much fun if Ford's Special Vehicle Team engineers hadn't nailed the new '03 Mustang Cobra's chassis calibrations right in the sweet spot."
Since the supercharger installation adds about 160 pounds to the front end once you add in the Eaton blower, the cast-iron block, and the intercooler installation, one might expect the resultant weight redistribution (56.6/43.4) to produce a nose-heavy car with snappy rear-end breakaway characteristics.But somehow that's not translated to the road, even with that phenomenal low-end-torque potential waiting for an injudicious stab of throttle. Somehow, SVT has made the chassis tolerate the nose-heavy weight distribution and big rear-drive muscle. Tolerate it? Hey, this thing loves the track.
The obvious point here is the engine, and blender whine aside, it's a gem. But the chassis was what really blew me away. Considering the age of this Fox platform, the SVT bunch did an incredible job. Every Mustang I've ever driven plows like a John Deere, but this one feels more inclined to do a four-wheel drift. I usually do four test laps on the skidpad. In this car I did 12; I couldn't help it. It'll turn tail-out, tail-in, or anything in between. You ever watch those lurid car slides in the movie Ronin? Here's your car to practice in. And don't be afraid it'll beat you up on the highway—it won't. If Ford ever gives these guys a modern platform, watch out.
So why replace the IRS bushings? for the 99-01 Cobra guys like myself who want an IRS that is at least as stiff as a Terminator, but wont cause nasty NVH increases, poly is a good compromise.
Some Cobra owners experence an extreme rear end sway under hard acceleration and the cause of this problem is worn out IRS Tie rod ends. Therefore eliminating the cobra rear end sway can be fixed by replacing the IRS tie rod ends. No need to touch the bushings.
Some Cobra owners experence wheel hop and think that replacing the IRS bushings will eliminated. Wrong. Remember this guy?
"Yup. Did the same mods as you. Still have the hop and now lots of gear noise too."
When you understand what really causes the Cobra IRS to wheel hop, you can see why the above situation happened. GM engineers discoverd that that IRS axel shafts are the root cause of wheel hop and fixed it with different dyamater axel shafts.
To quote GM:
Traction Limited
Even with the gigantic meats bolted to the backside, the ZR1 will be what is euphemistically called "traction limited." In other words, all that power just goes up into expensive smoke when you try to lay the power down.
And since launching a car with so much horsepower can become a violent, axle-hopping mess, Chevrolet has come up with two novel countermeasures.
First are the rear shocks. When you're stopped and the clutch pedal is depressed and you pile on some revs, the car assumes you want to launch it hard. It automatically softens the compression damping of the rear shocks, and this allows the rear end to squat and effectively shift more weight to the rear of the car for added traction. At the same time, the rebound damping of the rear shocks goes up to 99 percent of full stiffness. This means that the rear cannot spring back up under power in the up-and-down monkey motion of axle hop.
All this is perhaps the cleverest use of adjustable shocks that we've ever heard of. Also, according to Juechter, the standard magnetic shocks allow the ZR1 chassis team to use softer springs than the Z06 for a more compliant ride. To further mitigate power hop, Chevy has also fitted the ZR1 with axle half-shafts of different diameters (33mm on the right and 40mm on the left).
We'll see how all of this works next year when we finally get to drive the thing. We might just try a hard launch or, you know, several.
"6. Asymmetric shaft diameters (33mm left /40mm right) keep half-shafts from establishing a resonance in wind-up, thereby reducing propensity for axle hop.
6. Magneto-rheological shocks redesigned to cope with extreme track duty and provide base coupe ride quality. When drag-strip launch detected, shocks provide zero jounce and 100-percent rebound stiffness to encourage squat and minimize wheel hop
7. MR shocks allow spring rates to be softened slightly
8. Anti-roll bars stiffened"
The different size axel shafts and stiffened shocks makes sense. In my 2001 Cobra, I eliminated the wheel hop by installing 315/35/17 Goodyear eagle GSD 3 tires, Eibach pro kit springs and Bilstien HD aftermarket shocks that are stiffer than the 03-04 cobra units. None of the IRS bushings were replaced, not one! Hard to say witch mod cured the wheel hop since the springs, shocks and tires were done at the same time.
My next choice was do i go poly or do i go Delrin? After talking to my friend who had installed MM poly bushings in his cobra 4 years ago and only had 6,000 miles on the bushings, the choice to me was evident. I chose Delrin. Why did i make that choice? I made that choice because the poly bushings my friend put in 4 years ago that had only 6,000 miles on them were complete junk.
I doubt the Above statment is true. My Cobra has had a Set of Steeda Offset poly front control arm bushing since 2007 and even today, they are still fine and perfectly quiet. I expect no less from the Prothane and Maximum Motorsports IRS poly IRS bushings I installed in January 2013.
Bruce is a stand up human being
If your buddy Bruce is such a stand up guy, why did he respond in this thread with threats of violence against me with these words?
"I sincerely hope that a 6' tall, 290# ex-hockey or rugby player with a 700 RWHP Cobra, that lives in Northern California, actually takes your advice and puts those shitty poly bushings into his IRS. Then comes to hunt you down two weeks later to beat your ass for for giving out that lousy advice. My only hope is that the beatdown shows up on youtube.:laughing5:"
[/QUOTE]
