Upper intake ?
Green00gt
I know everything i need to run a fox upper on my car. But what all needs to be done to flip the upper around an point the tb toward the drivers side
IPhone set
wgeous
Go to junkyard and look for a cougar or tbird. Get throttle cable and bracket, I think the throttle cable is shorter. Get the air intake also. You will probably have to do some fabrication. You also might need the throttle body also. You can rotate upper intake to driver side, no problem. The only problem will be relocating battery. It can be done cheaply. Good luck.
96TANGERINEGT
forcedhatch , ran his like that on his turbo car for a while , but u can't talk to him cause he was banned ... i think for good ? (still make me upset by the way)
look up his build thread . it looks really cool
Green00gt
Green00gt
Thanks, Ill look into it. Main reason to do it is im goin to boost the car over winter I want to see what's the easiest way to intercool it
IPhone set
rz5.0
Great state of TEXAS
picture.php
this is the ezst way I found to do it
Staff online
