DFG_Pimpin said:
justinschmidt1 said:
the installation +parts would be over 2k
no it wouldn't, i don't know what backyard mechanic's do your work taht take 3Xs the regular labor time to install something at decent rates or you take your car to a ferrari machanic that is use to charging people whatever he wants...
Assuming you buy the 1400 dollar kit..how would installation not be over 600 dollars?
even if you pieced it together you would probably spend 1,000
I would imagine any mechanic would charge close to 1000 dollars to install all that crap.
They quote 700 to install cams around here.
You could probably run 13s with some drag radials, 4.10s and some weight reduction if you really wanted to..its hard to shed weight I guess.
You've got 4.10s, get some drag radials, pi intake and pi cams and you should be solid high 13s if you can drive.
drag radials, 3.73s, full exhaust, intake, and UDPs and i can run 13.6-13.7s all day easily. full NPI stock longblock...
You are such a vagina
You left out all these details like the fact that the car was stripped of a lot of shit and weighed like 3,000 pounds at the time and you were cutting 1.6-1.7 60 foot times.
heres what you said
so i weighed the car at the track at the end of the night, with a little bit less than 1/4 of a tank it weighed right about 3000 pounds. the car had no passenger seat, no back seat, no front sway bar, no spare/jack, i put my kirkey racing seat in.
The same car ran 14.7@97 you said...so with those mods, without the weight reduction the car ran 14.7 right?
Im just saying that you should probably include details like that.
In order to make your stang ( not gutted, no weight reduction) run 13s you will need more power, pi intake and cams.
Weight reduction does make a huge differance...but generally I think people want to run faster by making more power and not having to strip 500 pounds of shit off that you will put back in the car anyway.
