Used instrument cluster?
Basically in a nutshell, aint no way for it to work without INTENSIVE work and it still probably wouldnt work.
I wanted a Mach Cluster so bad. :(
dczsvt
dczsvt
Marshall, Missouri, United States
Thanks guys
It looks like it'd bolt right up to the dash but I wasnt sure if the plug ins would fit, so instead I just ordered my odometer gear from late model restoration and installed it and works great, now my car is actually turning miles :sad5:
vermilion
maryland
even some of the worm gears between the 95-98 arent compatible. unless you have an electronic variable speed sensor for the trans, newer computer, harness it will not work. if you manage to do all of that for the simplicity of electronics then it wasnt a simple swap. its costly to source the parts alone.
someone had a video recently on here that showed it. IT worked but it threw all kinds of err codes on it.
