Very interesting month. I had the wiring harness and relay for the fuel pump burn out. After replacing those items with a new one I noticed how hot the new wiring and rely were getting. I went ahead and purchased an Amp meter with a clamp which everyone should have. Pump read 37 amps when it should be 14 amps at idle. I sent in the pump to Magnafuel and those guys have excellent customer service and pleasant to talk to. Repairs where under $50 shipped back to me. Looks like from what I can tell the 25 micron filter got clogged and caused the pump to work extra hard to keep pressure up. The 74 micron filter was fine. A test that was suggested from the guys at MF is to run water through the filter from a hose. The water should leak out from the lower portion of the the filter without ever reaching the top and over flowing. I have not used the car that often and at times it has sat for multiple weeks or months without being started. MF suggested to start it at least every 2 weeks. Can't blame the pump but I will have to keep an eye on this for the future. I currently run a Protuner 750 which may be overkill for my current setup may get the 625 to reduce amp draw at idle.
On another note I finally got the Maximum Motorsports coil overs for the rear. Also got some QTP cutouts. I think I will mount them after the cats as I want the option to add cats if the fumes are too much. I will disconnect the X pipe and see how it sounds before I do any cutting. I will post up a vid once I am able to do so as pump has not arrived from MF.
Quick pic
I was running dual relays and both had burnt out. I am running a single relay now. Only reason for dual is to have a redundant relay. I noticed the voltage dropped considerably to 12.4 volts with fans on and I knew something was wrong.
Great tool to have ebay has it for around 25 for the 210 however if you want to read over 100 amps better to get the 204 model, I got both.
Notice the color difference on the mesh. I Got the 25 micron filter from MF but got a bigger filter. MF said that they have tried to cleaned the Filter but have not been able to and replacement is only alternative.
New low profile cutouts
Going after the cats green lines.
