Victor or Spyder
cornhusker
I have twisted wedge heads with stage 3 port. I need intake with best flow
So far I hear Super victor is the way to go then I started looking at the Spyder. I was told that the spyder is more like the victor jr flow.
Does anyone know which has the better flow?
modo
Philadelphia, PA
define stage 3... cfm?
too much intake and you will have little to no low end. unless you plan on spinning the motor between 7000-8000 rpm you do not need either one of the two mentioned
Paul
How many cubic inches do you have under there? What cam? Operating RPM? Intended use?
C
cornhusker
Actually it is a hydraulic roller. It has similar specs to a X303. I don?t know that it is the best blower cam but I haven't ran it yet.
Paul
8K rpm with a hydraulic roller X303?
Not bloody likely.
Also, why on earth are you using an x-cam on a 427? What heads are you using? Exhaust?
Paul.
C
cornhusker
Its not x303 its something like it, I don't have the cam card infront of me.
My heads are twisted wedge with stage 3 port.
I just asked about my intake and which is better to go with
I don't need someone being a prick to me on here.
Paul
We're not being pricks, we're digging for more information. You can't just ask "what intakes shoud I use" without providing the whole story. It's not that simple. We could just say "use intake blahblahblah" but it wouldn't be totally meaningless and irrelevant unless we were making an informed decision.
- we don't know what "like an X303" means for cam specs
- "stage 3" port is meaningless. What did they flow on the bench?
- what is the intended use of the car? Really.
- What is the operating RPM range, and don't say 8,000 RPMs because there is no way you'll be spinning that with hydraulic roller lifters.
Is this a real build, or a pipe dream?
Paul.
castine917
wyoming, mi
cornhusker said:
Has 427ci with s/c, an x303 cam, 4-5k daily, 6-8k strip.
4-5k daily with a s/c 427? cops, tire stores, and gas stations will love you. :drunken_smilie: i was shifting at 3k when stock.
which size trick flow were used as start? who made them stage 3? which supercharger?
thought you already had the victor intake?
C
cornhusker
This is a real build. Motor sits back at home in my garage.
I currently have 2 people that have both intakes and I'm just trying to figure it out so I don't pull them around.
Sorry for the snap, stressed.
blackpony
just use a stock one will save you money, if not knowing the other details matters, then why would it matter which intake to use..
