Want to delete Smog pump done this.
95blk5.0stang
Those anyboy know what size belt and the sequence to complete this task. I have no cats so theres no point to have the smog pump.
bill302
this is the article i used to remove my smog pump but i used a delete pulley click on link below, but in the picture below you will notice the top pic. which shows belt length without the smog pump and the lower pic. shows both a/c and smog pump deleted belt length. http://www.allfordmustangs.com//techarticles/Smog2.pdf
ripper
Theres no need to eliminate AC. Mythbusters has busted the MPG on that one and at WOT the clutch is off even if you have it turned on.
95blk5.0stang
thanks guys. I'll probably use the Smog n Ac belt sequence when Its gets a bit cooler out side. When its great track weather.
95blk5.0stang
I went to the local auto parts store.they don't have enough info about belts sizes. So I need a part number.
Paul
It's the belt that ends with 800 (80.0") or 805 (80.5") - The part numbers themselves are the belt length.
2plus2
if I delete the smog pump could I still run with the cats on for insection. no emissions they just look for cats.
R.C.
