idk whats up. i start the car and it can't idle worth anything.. it will start up, drop to like 200, stumble then die. after a bit, it will start idling fine but it feels like its missing. when i come to stops with the car still in gear and the clutch pressed down, the car will die, or almost die.. also, i was in 2nd gear and i kinda got on it to see what was up and the car just wouldn't go.. it hesitated, stumbled, bogged.. everything. car wouldn't go any faster, well it did but it was jerky as hell.
i changed the IAC valve with one off the other motor and it didnt do anything. then i replaced that tube that goes across the front of the upper intake and that FIXED it for like 5 minutes... so then i turned the car off and restarted it and it did it all over again.
anybody got any ideas? i already changed my idle settings with the XCAL2 to both 900 rpms on the idle in Drive and idle in Neutral....
