ryclef331 said:no. how big of a spacer do you run? You should only need 7/16" spacers. Thats it.
tRaV_19 said:ryclef331 said:no. how big of a spacer do you run? You should only need 7/16" spacers. Thats it.
i would say its a 1/2 if i were to guess cant remember right now ....but the tire is flush with the outside lip of the fender if i could loose that 1/2 or so it would help...and i have heard you can grind the caliper bracket but i dont think taking a 1/2" off is "safe" lol maybe i should get a shorter tire to help
ryclef331 said:tRaV_19 said:ryclef331 said:no. how big of a spacer do you run? You should only need 7/16" spacers. Thats it.
you can safely grind that bracket and it will be fine.
As for the fox arms, you can run those and they'll pull the track width in 3/4" per side. You gotta run the fox tie rod ends too.
ryclef331 said:As for the fox arms, you can run those and they'll pull the track width in 3/4" per side. You gotta run the fox tie rod ends too.
DFG_Pimpin said:ryclef331 said:As for the fox arms, you can run those and they'll pull the track width in 3/4" per side. You gotta run the fox tie rod ends too.
why do you need to run fox tie rod ends?
ryclef331 said:DFG_Pimpin said:ryclef331 said:As for the fox arms, you can run those and they'll pull the track width in 3/4" per side. You gotta run the fox tie rod ends too.
b/c the control arms pull the spindles inboard...if you don't shorten the tie rods up the same, you end up with a shitload of toe out i.e....wheels pointed like this \-----/ and the stock tie rods don't have enough adjustment on them to fix that.
ram360 said:you guys using longer than stock wheel studs up front when using the spacers and the 15x3?
