Well, there goes a wad of money...
PinkieT
Cleveland
Years ago I swapped my stock 2-something rear axle for one from a Cobra from a guy upgrading to a 9 inch for his turbo motor. Well, I started getting whining on acceleration and a clank sometimes when I stop. Pulled the fill plug and look what I found... Got a quote for $1,200 to $1,400 if gears are needed, more if the limited slip is bad too. $800 if just bearings. Yikes!
PinkieT
PinkieT
Cleveland
Checked with three local garages I trust. None do it and all sent me to the same place where I got the quote. There is a Mustang performance shop nearby I'm checking with. A buddy has a clean 3.73 ring gear set with limited slip and bearings but no pinion gear he is giving me for free for parts. He accidently left the pinion in the axle when he sold it, dammit!
Wmac
Steeltown, Ontario
When you say Cobra axle, are you referring to a 31 spline diff?
FRPP gear set ........... 200 bucks or so.
FRPP gear install kit .. 100 bucks or so. (has all the bearings needed)
FRPP tracloc rebulit kit.. 100 bucks or so.
FRPP axle berings & seals... 35 bucks or so.
Rebuilt like new for 400 plus labour. Any mustang shop can do this.
Need 28 spline axles or spiders? Meet me in Niagara Falls halfway across the Rainbow bridge and I'll hand those to you for free. (lol)
PinkieT
PinkieT
Cleveland
Have a Mustang shop I'm checking with Monday, and a local trans shop that is supposed to do differentials. The axle is out of a 98 Cobra, straight axle not an IRS. No idea how many splines until it is apart. The shop that quoted me over a grand for the job is busy and I couldn't get in for over six weeks anyway.
PinkieT
PinkieT
Cleveland
Local trans shop quoted $2,500! Yeah, right, dudes! Mustang specialist was lowest price of the three and has a great reputation. Got an appt. for next month to get it done.
joe65
if its the stock 98 cobra it will be 28 spline. they went to 31 on the 2001's. (Cobra). Check Ebay for trac lok diffs. I've found some there for a good price. I also have one i'd sell. It could probably use new clutches. but it was working fine when i pulled it.
PinkieT
PinkieT
Cleveland
OK, it's in the shop and they started taking it apart. Differential has a crack, spider gears are worn big time. No wonder it made noise! So far the gears in it look OK. They have the complete Ford Racing 3.55 gear set with install kit I bought for it, and I brought them a spare differential. Thinking just having them install the new gears, use up the kit and have all new stuff.
RAU03MACH
NEW MEXICO
Would you do 373
Just a little more Getty up
RAU03MACH
NEW MEXICO
did you notice before if the axel shafts have a lot of in and out play back and forth other words
they would slam back and forth on the spider gears and that's usually what happens to them
I have seen that happen twice
PinkieT
PinkieT
Cleveland
Never noticed it, but I'll ask the shop to check. Would that be from bad axle bearings?
PinkieT
PinkieT
Cleveland
Murphy's Law kicked in. The differential my buddy gave me is good, but I have 28 spline axles and it takes 31. Trip to Summit, more $$$$ out the window....
PinkieT
PinkieT
Cleveland
Picked up the axles at Summit yesterday. Their house brand 31 spline axles was $209 a pair including studs and bearings. Bought my wife a black and pink Mustang ball cap while I was there, the least I could do since I dipped into family cash to buy the axles. Got the car home today. The tech showed me metal chips they fished out, including tabs from the Trac-Loc clutches. Gonna sell the old axles and whatever else is still good to try and get some of my money back. Driving her gently until the gears are broken in, then plan on testing out the Trac-Loc big time!
