What exactly is missing in my Supercharger Kit?
SonicStang
I know there are missing a couple parts to make it complete, but can you tell me which ones exactly? Check out the picture I took.
I am guessing the following is missing:
- Fitting for Oil pan (for oil drain hose)
- Fitting for Oil feed hose
- 3-1/2" Flex Hose
- Short hose from Bypass Valve to Plastic Elbow
- Radiator Hose Extension
- Passenger Coil Relocation Bracket
- XCal (I don't want to use the FMU)
What else? Anyone having an idea where to order this crap?
Tornbetween2
Yea you might be right. Does anyone know what size the stock crank pulley is?
SonicStang
Yeah you use the stock one. So where can I buy the missing stuff?
ju015dd
tallahassee, fl
i have the oil drain hose assy which comes with the fitting you will need. i paid 28 bucks from vortech you can get it for 20 shipped.
ripper
I dont see a fuel pump. You need a 255gph along with your in tank. You also need to change your plugs DO NOT use platinum plugs. I use autolite 103's gaped @ .035
Heres what happens to platinum plugs and s/c lol
[attachment deleted by admin]
SonicStang
Fuel pump is on the lower left, a walbro 255. I recently bought a AMS power pipe so what's still missing is the coil bracket and the Xcal2 I believe. I am already running NGK iridium plugs.
ripper
Powerpipe will add like 2lbs of boost good choice.
Tornbetween2
So where are you going to get these parts?
I Would like to see what that coil bracket looks like because i need one also. i think vortech wanted like $57. i also need a radiator hose extension.
So Let me know where the cheapest place to get these things or if someone wants to show pictures of these things so i can make them. that would be great!
SonicStang
I am looking to create that bracket by myself. Once I have made a template I can scan and send it to you.
As for the radiator hose extension I forgot about this part. I will try www.superchargersonline.com maybe they have it.
It would be great if anyone could post a picture of that coil pack bracket. Would make it a little easier to fabricate it.
SonicStang
Actually you just need a sheet aluminum and a Dremel tool. The template should look like the one I quickly sketched. I'll give it a try. Just need to find out the exact measurements.
Tornbetween2
Yes they do sell it there. it is $57 from there and $57 from vortech. it would be nice if someone chimed in with the dimensions
Tornbetween2
What size is that radiator hose extension?
Anyone???????????????????????????????????????????????/
bs.austin.tx
