what gears?
rideorange812
Everyone said a 373 for the 95 but I'm also building a sc 347(taken a while due to other builds haha) so I wanted to do a 3.55 so I wouldnt waist my money later redoing gears because I want a car that has top speed at VIR as well. so what do you think about 3.55s?
project94
man i love my 373. but then again your building a 347stroker which isnt as high reving as the 302. idk man. it would suck when u get it all together and come to find out 373 is what u wanted
R
rideorange812
well i mean me and my dad are spending the money to get the revs of a 4.6 were going for 6,800 for the power drop and 7000 redline for mistakes. so i calculated 355 withs get me 160+ while 373 is like 149s and il be getting my ass busted with 355s but alot of the cars at vir at 160 haha but i gotta be streetable to.
Spd0lit
SoCal
Is this drag racing or road racing. Because if you are trying to trap 160 in the 1/4 good luck. :hammer: I don't even think you would want to go that fast road racing. 3.55s will put you at 134 mph at end of 4th and 3.73 will put you at like 123mph at end of 4th.
Spd0lit
SoCal
Talk to replicar the suspension mod about road racing. I've been in his car and it is quite fun for stock motor.
2slo95fiveoh
Lawrence, Kansas
3.73 should be fine. like stated before, you wouldn't want to install 3.55 only to find out later you want 3.73. besides, if it's not going
to be the daily driver, then why not step up to the larger gear?
95-stang
I put in a 3:73 axle, well happy with it, it goes well off the line, and i can still cruise at 70mph [just over 2k rpm] on the motorway. :)
i'm kinda thinking the other way. 355's and here's why: 1st- your looking for top speed on a road course, 2nd- your motor is going to be making more power and torque and the reason most change gears is because that's what they don't have.
rideorange812 said:
not for long
Mine is not my DD either,but later down the road i want to use F/I. and bigger gears seem worthless,specially if you go with a Centrifugal SC.IMO.
So 3.73's.should be fine.
that goes both ways tho, regardless of what gear is the right choice I'd rather be stuck with a lil less gear than i want rather than too much. His power is going to make up for not having a steep gear anyways and it's nice when 1st gear is usable.
R
rideorange812
I think I'll get 3.55s they make more sense. Thanks for all your opinions I'll let ya know how it goes.
what gear do you have in it now? the code on the my door reads that i should have 3:55 stock ( i now have 4:10) maybe you can get lucky and have those already in it.
I think i found the info at another mustang forum and verified it on the door tag. i don't have the info in front of me right now(at work ) but i'll look for it later if you need it
OK i was wroooo. i was wroooon. i stand corrected. mine had 3:08's stock
M=code 2.73
Z=code 3.08
E=code 3.27
The only Mustang that came with 3.55's is the 03 cobras,as far as i know.
Maybe the Cobra R have bigger gears, but im not sure.
