What injector size?
topless95
I am installing a set of x303 heads, a E-cam, performer intake this weekend and was wondering will I need to go to 24lb injectors to get the full benefit of the H/C/I upgrade? Also would I need to upgrade to a 70mm throttle body?
As always thanks in advance
Jim
LAFENATU
Not needed by any means but gives you room to grow.
Stock 19's will support close to 300 HP N/A.
LAFENATU
Venom351R said:
300 HP at the motor.
Trust me, 19's will support what he has.
I didn't say don't get 24's - it will give him room to grow but 19's will support the power he is making.
Venom351R
Maine
Depends on if he never does anything to the car ever again to increase the power. If so hes going to need #24's anyway.
v6stang3215
You do not NEED them. They will probably help however. I would think with that setup he will be close to 300 hp anyway. If you plan on doing more to the motor then upgrade the fuel injectors. It can't hurt especially if you can get them for a good deal. The throttle body will also do a little bit to help your setup.
