What is this popping noise...
lilj4u2njoy
Forest City, NC
So my car has been sitting for a few weeks wile I was outta town, not sure if this "popping" noise was already there but I notice it now. It happens when i take off or if I rol up to a stop sign and not stop completely... It's comming from the rear and it's a slight pop then I don't hear it anymore... What could it be?
Is it RPM based? Right or left?
Might be U-joints or maybe a rear disc brake dust shield to touching a wheel. It might be something on the ABS reluctor wheel
330CubeGt
Prob a u Joint but who knows, hard to tell if your not in or around the car yourself...
ivan12
It's pretty easy, undo the driveshaft from the rear end and pull it out of the tranny tail. It takes a 12mm wrench with a 12 point end. You can have the joints pressed out and in or you can do it yourself with a vice. Check the inside of your wheels to make sure there's no oil on them, I had a similar problem a while back and it turned out to be my joints and a rear end bearing.
ivan12
Before you buy the u joints jack the car up safely, get under it and rock the driveshaft back and forth paying close attention to both joints for excessive noise or movement
silverv6
Florida
mine does it sometimes in reverse and when i pull off after it does it in reverse.. Its not all the time so i turn my radio up and ignore it lol
