What is this white connector near PCM 98 MUSTANG GT
New York
The white connector at the top of the picture, has one yellow wire coming out of the other side
, All data just crashed on my computer so i can't look it up,
also there is what appears to be a two wire ground( red and black) near the pcm, does anyone know where that goes?
mcglsr2
Orlando
If this isn't updated by the time I get home from work today, I'll take a look in my manual and see if I can help identify it.
Ok, so I just pulled the heater box out of the way and I see the one yellow wire. However, it goes into the main harness and I haven't opened it up yet. So I will not be able to trace it right now, I think it would be best if [MENTION=15705]mcglsr2[/MENTION] could find it in his schematics.
B
New York
Thanks for looking I'm going to try and see if I can find it on all data again when I get home
mcglsr2
Orlando
Alright, so I looked in my wiring manual (I have a 95) and I found a connector that *could* be what you are asking about - it's labeled as Connector 208 in the book (C208) however it's never actually mentioned in any wiring diagrams. So I went and looked on my car and sure enough - I don't have that white connector. So whatever it is, I'm guessing it got added later on, possibly with the swap to the mod motors.
You said there's 3 wires, right? A red, a black and a yellow? Typically black is ground, red is +12V IGN, and yellow is +12V BATT. That connector just may extend those wires to other parts of the car? I'm totally guessing here, you'd have to put a multimeter on them to see if there really is any voltage. Or perhaps find a manual for a 98, see what that says. Sorry I can't be more help :(
B
New York
I think there were 4 wires on one side but only 1 (yel/org) on the other. Which didn't make sense I also couldn't did it on any diagrams I'll have to look again
mcglsr2
Orlando
Yah 1 wire on 1 side and 4 on the other doesn't make much sense either. The only way I can think of why that would happen is whatever is on the 1 wire is being split to go to 4 difference places, and rather than using a solder joint for each of them they just broke it out using a connector. Is the 1 wire a lot thicker than any of the 4 wires? Maybe that's why it's not showing up on diagrams, because it doesn't really do anything other than act as a split? I'm not sure I really believe that though, I haven't seen Ford do that anywhere else on the car. Connectors are usually 1 to 1. Not sure man, this one is tough to track down.
I chased it down in my harness, it is pin 12 on the ecu plug. So that says it is for the fuel gauge. I have some pictures from my harness ill post up in just a few.
mcglsr2
Orlando
So wait, there's 1 wire on the one side that goes to pin 12 on the ECU, and then *4* wires that come out on the other side of that connector...? Pics of what the inside connecting part looks like please.
***For the record, this circuit now confuses me. I do not understand what is going on here.***
Alright, here is the plug with its wire. I have the wire looped around itself so you can see all of it
Now inside that plug
The other side, inside the car.
Inside that plug
B
New York
What i am thinking is there are extra wires for different options maybe. know that i know what the one wire is for I'm going to look through, Mitchell on demand again and see if i can find the rest
I am truly dumbfounded by this connector
I think I lost track, but what exactly is your question regarding this thing?
B
New York
I just wanted to know what it does, I didn't have it plugs in because i didn't think they went to each other, because of the 4 wires on the one side and 1 on the other
and after plugging them in i didn't notice anything happen
I was also really confused why there would be 4 wires on the one side and 1 on the other
stillridin
