what kind of gears with supercharger??
Lightning Struck
it all depends on what kind of blower yu have and what kind of motor it is on, so.......... :dunno: I think MOST guys run the 3:73 gears though.
Dalamar
SLC, UT
Usually ppl go with a 373 for a centrifical - makes up for the lag.
355 or lower on a posative since the low end boost will have traction problems with high gears.
I have a 373 in mine now, when I go turbo I'm gonna drop it to 327's, high HP. :D
94TURBO5 0
IMO yup 3:73's are good 2 go. I ran them with all my blower combos and I run 3:08's now with the turbo.
scarface
Guest
Im running 3:73s, and Im going to change to something higher soon. I have no traction threw 3rd.
G
g_dogg
dalamar do u like you 3.73 right now? or you find they are not enough?
Dalamar
SLC, UT
Feels great. I'm still NA ;)
If I was staying NA I'd go to 410, otherwise 373 feels great! still get good freeway milage in OD.
G
g_dogg
SvtBlack95 do you have any traction problems with 3:73's?
95CALI-5.0 do you sometimes wish you had 3:73 instead of 3:55?
95CALI-5.0
I like my 3:55. I do alot of open track driving and am on the highway alot. power wise I can break traction all oof 1 - 2 gear and part of 3rd. That;'s with BFG's KD rubber. So if I went with the 3:73 my traction problems would get worse. If you stick to 355 or 373 you should be very happy with a blwn combo.
9psi 98
I'm running 3.27's in my Stang. They were in it when I bought it and I thought that the guy who owned it before me was scared of the SC. The more I drive the car, I realize that I can't go much higher. I spin through 1st, 2nd, and finally chirp and hook up in 3rd. I was thinking about swapping to 3.73's, but I'm really against it now. I'm still considering 3.55's, but with gas prices skyrocketing for the summer, I'm kind of enjoying the extra gas mileage in OD with the 3.27's... :eek:uttahere:
9psi 98
Whistler98 said:
I have 4:10's and love them with my 4.6 and p1sc @ 8lbs.
You must spin soooo much. No sense in having all this power if you're sitting at the line making a bunch of smoke.
Whistler98
Southwestern, Pa
Thats why they make drag radials. At some point I will prob go with a 3:73 when I rebuid the motor with heads and cams but for now I love how the 4:10s get my centri in the power band quicker. If I had a positive displacement blower though I prob wouldn't want the 4:10s.
9psi 98
That explains it then, the centri blower has a little bit more lag than my roots. I'd probably run 3.73's if I were in your driver's seat as well.
Cregar24
